backlash eliminating star October 17, 2015 04:30AM |
Re: backlash eliminating star October 17, 2015 06:29AM |
Re: backlash eliminating star October 17, 2015 02:07PM |
Re: backlash eliminating star October 17, 2015 02:29PM |
Re: backlash eliminating star October 18, 2015 04:06AM |
Re: backlash eliminating star October 18, 2015 10:27AM |
o_lampe
I've mounted my extruder in half height onto the x-tower. Others have mounted their stepper on the top horizontal struts... There is no standard answer to that.
The installation with springs and center ring are halfway up on the rods. In my case it would have a clearance of 12cm to the effector. The ring might never get in contact with the Bowden tube, we'll see.
-Olaf
Re: backlash eliminating star October 18, 2015 12:02PM |
Re: backlash eliminating star October 18, 2015 12:41PM |
dc42
Dougal, which Igus rod ends do you use, and where do you get them from?
Re: backlash eliminating star October 18, 2015 02:07PM |
dougal1957
dc42
They are the IGUS KBRM-03 direct from IGUS They wont supply individual's (Unless your liberal with the truth Lol) only Businesses they come in at 1.92 + for quantities above 10 see KBRM-03 Rod Ends.
I have a second set in the post and Carbon Tube can be got from Carbon Tube
HTH
Doug
Re: backlash eliminating star October 18, 2015 02:22PM |
dc42
dougal1957
dc42
HTH
Doug
Thanks!
Do you find the 5mm x 3mm tube rigid enough? My 6mm x 4mm tube bends a little more than I would like, and I was thinking of going up to 8mm. But all the Igus joints I have found use the same hole and thread sizes.
Is there a reason why you chose the woven tube instead of the pulltruded tube?
Re: backlash eliminating star October 18, 2015 09:58PM |
o_lampe
Now the pulling force on the carrier-wheels is always aiming to the center-ring. No "forced wobble" anymore.
Re: backlash eliminating star October 19, 2015 04:55AM |
Re: backlash eliminating star October 30, 2015 12:32AM |
dougal1957
Fortunatly I don't have the problem so don't need to stabilise it (I use openBuilds Mini V-Wheels on there Vee slot extrusion and use a custom slider block with eccentric spacers to allow for adjustment and use 4 wheels on each carriage (tho that could be reduced to 3 if needed).
Re: backlash eliminating star October 30, 2015 03:24AM |
simspeed
[attachment 64970 Carriage.JPG][attachment 64971 Carriageside.JPG][attachment 64972 Carriagerear.JPG]Quote
dougal1957
Dougal1957 ....I'd sure like to see pictures of your v-slot mini wheel carriage set up. I'm using the same components for the enclosed delta I'm building. I went with the magnet ball/carbon rods setup from Werner Berry. His rods measure 9.5mm dia.
Re: backlash eliminating star October 31, 2015 09:12AM |
Re: backlash eliminating star October 31, 2015 05:04PM |
Re: backlash eliminating star November 02, 2015 03:53AM |
Billhc83
Those igus rod ends list max range @ 30* I am assuming this would make a total of 60* range of motion, how does that compare to the Traxxas joints?
Re: backlash eliminating star December 23, 2015 05:28PM |
o_lampe
Hi guys,
inspired by nebbians rubberband anti wobble hack, I sketched up a version that eliminates backlash in the rod ends as well as any play in the carriers.
It combines the well known "anti-backlash spring" between the rods and nebbians approach to eliminate wobble and play in the v-slot rollers.
-Olaf
Re: backlash eliminating star December 23, 2015 06:39PM |
Re: backlash eliminating star December 23, 2015 06:42PM |
DjDemonD
Seems like a good idea. Makes me wonder if I am inadvertently achieving the same effect with a flying extruder since the extruder is attached by elastic to each of the carriages effectively pulling them towards the centre of the printer.
... it would be cool to have killed two birds with one stone. I am also contemplating at a flying extruder.|
Re: backlash eliminating star December 23, 2015 07:01PM |
Although it has to be said, I can't see any difference in print quality between rollers with the rubber band hack, and linear bearings, at least at this stage.|
Re: backlash eliminating star December 24, 2015 04:01AM |
