can't find kossel 2020 firmware March 05, 2016 09:15AM |
Re: can't find kossel 2020 firmware March 06, 2016 11:38PM |
Re: can't find kossel 2020 firmware March 07, 2016 08:35PM |
Re: can't find kossel 2020 firmware March 08, 2016 08:58AM |
Re: can't find kossel 2020 firmware March 11, 2016 07:22PM |
Re: can't find kossel 2020 firmware March 15, 2016 01:12AM |
Re: can't find kossel 2020 firmware March 20, 2016 06:53PM |
Re: can't find kossel 2020 firmware March 20, 2016 09:33PM |
Re: can't find kossel 2020 firmware March 21, 2016 03:02PM |
Re: can't find kossel 2020 firmware March 22, 2016 02:00PM |
Re: can't find kossel 2020 firmware March 22, 2016 03:03PM |
Re: can't find kossel 2020 firmware March 23, 2016 10:53PM |
foryst
If it digs/floats in a concentric pattern (i.e. floats in the center, digs on the edges) then your concavity is off, which is fixed via DELTA_SMOOTH_ROD_OFFSET in Marlin or PRINTER_RADIUS/ROD_RADIUS in Repetier. If it float/digs in a linear pattern (like the right half floats above and the left half digs in) then you'll need to do better physical bed leveling and/or endstop adjustments until the bed is at the exact (or as close as possible) bed height at points near all three towers, and -then- worry about doing concavity adjustments via the aforementioned variables (and this is also where DC42's website becomes super duper extra valuable in saving time, since it'll give you optimal or near-optimal numbers with maths instead of lots and lots of trial and error).
Re: can't find kossel 2020 firmware March 24, 2016 12:11PM |
Re: can't find kossel 2020 firmware March 24, 2016 06:36PM |
foryst
You may need to use RepetierHost (free printer driver software, and decent) to set them then. Once they're set, they should work regardless of what printer driver software you're using in normal day-to-day printing (like, I had to set mine using RepetierHost, but have been toying with MatterControl as my main print driver, since RepetierHost abandoned mac a few years back). If you're on a windows or linux machine, I know a lot of people keep with the Repetier firmware and RepetierHost combo for the added benefits that the newer versions offer.
Re: can't find kossel 2020 firmware March 25, 2016 10:05AM |
