Re: Large Kossel all metal delta build log September 11, 2016 08:45AM |
Re: Large Kossel all metal delta build log September 11, 2016 08:56AM |
Re: Large Kossel all metal delta build log September 11, 2016 05:02PM |
Re: Large Kossel all metal delta build log September 13, 2016 05:36AM |
Re: Large Kossel all metal delta build log September 13, 2016 10:41AM |
Re: Large Kossel all metal delta build log September 13, 2016 01:36PM |
DjDemonD
Was thinking about a thermal fuse on the bed heater maybe the maplin 157 deg C type. I would crimp it on in series with one of the AC leads to the bed heater, protect the leads with heatshrink and place it under the silicone heater at the edge? Or is there a better way?
I presume to use one on the hot end it would have to be more like 300 deg C and be attached to the heater block? I'm not sure this one is as useful as the bed heater.
Re: Large Kossel all metal delta build log September 15, 2016 04:48AM |
Re: Large Kossel all metal delta build log September 16, 2016 07:47PM |
Re: Large Kossel all metal delta build log September 17, 2016 04:10PM |
Re: Large Kossel all metal delta build log September 17, 2016 04:23PM |
Re: Large Kossel all metal delta build log September 18, 2016 07:04AM |
Re: Large Kossel all metal delta build log September 20, 2016 04:13AM |
Re: Large Kossel all metal delta build log September 20, 2016 07:02PM |
; Auto calibration routine for delta printers M561 ; clear any bed transform, otherwise homing may be at the wrong height G31 X0 Y0 ; don't want any probe offset for this G28 ; home the printer G28 ;home again in case of endstop problem ; Probe the bed and do 6- or 7-factor auto calibration positions are probe positions (x-13,y34) G30 P0 X-87 Y-86 Z-99999 ; X tower G30 P1 X13 Y-140 Z-99999 ; XY point G30 P2 X104 Y-90 Z-99999 ; Y tower G30 P3 X130 Y16 Z-99999 ; YZ point G30 P4 X13 Y100 Z-99999 ; Z tower G30 P5 X-100 Y40 Z-99999 ; YZ point G30 P6 X-50 Y-60 Z-99999 ; X tower middle G30 P7 X0 Y-100 Z-99999 ; between X and Y towers middle G30 P8 X80 Y-70 Z-99999 ; Y tower middle G30 P9 X80 Y-10 Z-99999 ; between Y and Z towers middle G30 P10 X13 Y60 Z-99999 ; Z tower middle G30 P11 X-57 Y054 Z-99999 ; between Z and X towers middle G30 P12 X-27 Y-64 Z-99999 ; X tower inner G30 P13 X53 Y-64 Z-99999 ; Y tower inner G30 P14 X13 Y6 Z-99999 ; Z tower inner G30 P15 X13 Y-34 Z-99999 S7 ; centre, and auto-calibrate 7 factors G1 X0 Y0 Z150 F10000 ; get the head out of the way of the bed
;bed level check G30 P0 X-100 Y-60 Z-99999 ; X tower G30 P1 X100 Y-60 Z-99999 ; Y tower G30 P2 X0 Y100 Z-99999 S-1 ; Z tower G1 X0 Y0 Z100 F10000
Re: Large Kossel all metal delta build log September 21, 2016 05:23AM |
Re: Large Kossel all metal delta build log September 21, 2016 01:49PM |
Re: Large Kossel all metal delta build log September 21, 2016 02:42PM |
Re: Large Kossel all metal delta build log September 21, 2016 02:50PM |
Re: Large Kossel all metal delta build log September 22, 2016 04:56AM |
Re: Large Kossel all metal delta build log September 22, 2016 07:57AM |
Re: Large Kossel all metal delta build log September 22, 2016 08:41AM |
Re: Large Kossel all metal delta build log September 22, 2016 03:01PM |
Re: Large Kossel all metal delta build log September 22, 2016 03:24PM |
Re: Large Kossel all metal delta build log September 22, 2016 04:09PM |
dougal1957
Have printed out the Flying extruder parts must say I wondered why they had all the cutouts and holes etc then when it came off the bed (Well whilst it was still printing actually) that it is effectively a scale model of the upper frame (Or maybe the Lower one). Looks very nice and will re-do the carriage pieces to fit my Robotdigg one and get it mounted soon and see the Difference?
Doug
Re: Large Kossel all metal delta build log September 22, 2016 04:11PM |
Re: Large Kossel all metal delta build log September 22, 2016 07:23PM |
Re: Large Kossel all metal delta build log September 26, 2016 06:38PM |
Re: Large Kossel all metal delta build log September 27, 2016 04:12AM |
Re: Large Kossel all metal delta build log September 27, 2016 06:12AM |
Re: Large Kossel all metal delta build log September 27, 2016 10:36AM |
Re: Large Kossel all metal delta build log September 27, 2016 12:54PM |
DjDemonD
One other issue with this magnet system that might be coming into play here, does this seem logical?
The balls are not magnets, at least until they are attached to the magnets in the carriages, then they will become magnetised.
[attachment 84295 20160927_144119.jpg]
Since the machine sits at rest with the arms at around 60 degrees to the effector, the balls develop a north and south pole over time. This might be less of an issue if the machine were in continuous use, but it isnt. So when the arms are at a very obtuse angle to the effector the poles are not aligned, there is still attraction to the balls, as they are only weak magnets compared to the magnets themselves, but the attraction is weaker than at the acute angle.
Is this plausible? It seems to chime with the fact that the holding force at obtuse angles seems less now, than it did when I first brought magnet and ball into contact. Maybe the effector needs to rest unattached to the magnets when not in use.
