Re: Skewed print any ideas? December 23, 2016 01:22PM |
Re: Skewed print any ideas? December 23, 2016 01:40PM |
Re: Skewed print any ideas? December 23, 2016 01:49PM |
Re: Skewed print any ideas? December 23, 2016 01:52PM |
Re: Skewed print any ideas? December 23, 2016 03:56PM |
Re: Skewed print any ideas? December 24, 2016 03:57AM |
Re: Skewed print any ideas? December 24, 2016 04:20AM |
Re: Skewed print any ideas? December 24, 2016 05:36AM |
Re: Skewed print any ideas? December 24, 2016 05:44AM |
clearlynotstefan
Woooooo! Odd, that it'd happen at the same height but with different xy positions seems very weird to me.
Re: Skewed print any ideas? December 24, 2016 06:05AM |
Re: Skewed print any ideas? December 24, 2016 07:25AM |
Re: Skewed print any ideas? December 24, 2016 09:35AM |
Re: Skewed print any ideas? December 24, 2016 10:24AM |
Re: Skewed print any ideas? January 03, 2017 03:14PM |
Re: Skewed print any ideas? January 03, 2017 03:17PM |
Re: Skewed print any ideas? January 03, 2017 03:27PM |
Re: Skewed print any ideas? January 03, 2017 03:35PM |
Re: Skewed print any ideas? January 03, 2017 03:39PM |
Re: Skewed print any ideas? January 03, 2017 03:41PM |
Re: Skewed print any ideas? January 03, 2017 03:47PM |
Re: Skewed print any ideas? January 03, 2017 04:15PM |
Re: Skewed print any ideas? January 03, 2017 04:33PM |
Re: Skewed print any ideas? January 03, 2017 05:11PM |
Re: Skewed print any ideas? January 03, 2017 05:27PM |
Re: Skewed print any ideas? January 03, 2017 07:53PM |
Andreas15
I know it's not really the topic here, but do you think there is an advantage in using an idler with teeth instead of a smooth one and running the back (twisting) of the belt on it?
Re: Skewed print any ideas? January 03, 2017 08:06PM |
Re: Skewed print any ideas? January 04, 2017 04:24AM |
dc42
16 tooth pulleys have the advantage that the Z height change per microstep is a nice round number, e.g. with 16x microstepping it's 0.005 or 0.01mm depending on your motors. With 20 tooth pulleys you get 0.00625 or 0.0125mm.
Re: Skewed print any ideas? January 04, 2017 04:58AM |
Re: Skewed print any ideas? January 04, 2017 08:56AM |
o_lampe
dc42
Is that really an advantage?
I know from gearboxes, that they intentionally use gears with prime numbers. ( eg,17 tooth ) Don't know, if there are similar effects seen with belts'n pulleys, but it would be worth trying 17 toothed pulleys.
Has anyone seen herringbone belts and pulleys?
Re: Skewed print any ideas? January 04, 2017 10:23AM |
