Re: Skewed print any ideas?
December 23, 2016 01:22PM
No I'm just joking I haven't had chance to change the belts yet, it prints okay at 50mm or higher so if it printed everything onto a 50mm raft it would work.
Edited 1 time(s). Last edit at 12/23/2016 01:25PM by DjDemonD.
Simon Khoury
Published:Inventions
December 23, 2016 01:40PM
Thank God for that you nhad me worried there a 50mm raft would be insane?
December 23, 2016 01:49PM
I was starting to suspect a firmware bug until you raised the bed 50mm and the problem went away. Now I think you may have a problem with your linear rails, sliders or carriages. Are you quite certain that none of your carriages is rotating about either its face or the Z axis over that bottom 50mm of height?
I recommend you put a bulls-eye spirit level on your effector if you don't have one already, to help detect effector tilt. I have a lot of spare ones, so if you are in the UK, drop me a PM.
December 23, 2016 01:52PM
I've got one on there but thanks for the offer. It has a slight tilt but it's consistent at various x, y coordinates. I suspect it's the positioning of the spirit level or a lack of a genuinely flat level surface in the effector to place it.
None of the linear rail carriages have any play, the printed carriages on them are solid, so are the rods and now the effector after I beefed it up a bit. Belts might be the culprit as I tightened the x belt about 10 days ago, but now it's a bit loose again, so maybe the steel wires are snapping.
Might get chance to swap them out for non metal belts tonight.
Edited 2 time(s). Last edit at 12/23/2016 01:56PM by DjDemonD.
Simon Khoury
December 23, 2016 03:56PM
The fact that it offset by the raised bed narrows the field significantly. Sadly that almost makes it worse, as it rules out most of what I thought it could be! Localized Mechanical binding and carriage issues wouldn't do it. The carriages only have to move 50mm in unison to get past your trouble zone, but much more to try the print on the other side of the bed.. If it was a troublesome area of v slot or something you wouldn't get the same result.
I've got no idea what's going on, but I DO know that when you figure it out the whole damn delta reprap crowd is gonna rejoice with you haha
December 24, 2016 03:57AM
That's for sure!
December 24, 2016 04:20AM
WOOOOOHOOOOOOOO !!!!
Sorry, was a bit overcome there. SOLVED......
It was the belts. Now using common or garden black fibre reinforced GT2 belts and printing 100mm tall straight towers.
A massive thank you to everyone who has contributed here.
Steel reinforced belts and 16 tooth pulleys - maybe not such a good plan.
Merry Christmas and Happy New Year smileys with beer
ADMIN - could you change the title of the thread to include SOLVED?
Edited 1 time(s). Last edit at 12/24/2016 04:24AM by DjDemonD.
Simon Khoury
December 24, 2016 05:36AM
Woooooo! Odd, that it'd happen at the same height but with different xy positions seems very weird to me.
December 24, 2016 05:44AM
clearlynotstefan
Yes it's strange. I admit when I tried test prints around the bed I didn't go to the extremities.
Simon Khoury
December 24, 2016 06:05AM
Nice work DJ, good to see that the persistence paid off.
Merry christmas, and happy printing smiling smiley
Edited 1 time(s). Last edit at 12/24/2016 06:06AM by nebbian.
December 24, 2016 07:25AM
Whooooo nice to see it's sorted.
all the best to you and your's?
Doug
December 24, 2016 09:35AM
Just became a Grandfather and now this!
What a year ending this it turning out to be.
Congrats!
December 24, 2016 10:24AM
Congratulations. That's awesome news. Sounds mad but I've really enjoyed this problem thanks to this community. Have a great Christmas everyone.
Simon Khoury
January 03, 2017 03:14PM
Are you still using the 16 tooth pulley now? Or did you swap them for 20's?
January 03, 2017 03:17PM
Still on 16s swapped belts to more standard rubber & fibre glass with inline tensioners.
Autocalibration deviation dropped from 0.02 to 0.04 so there is something in those steel belts (steel obviously) would be keen to try polyurethane and kevlar/aramid to see how they compare to neoprene/fibreglass.
Edited 1 time(s). Last edit at 01/03/2017 03:26PM by DjDemonD.
Simon Khoury
January 03, 2017 03:27PM
16 tooth pulleys have the advantage that the Z height change per microstep is a nice round number, e.g. with 16x microstepping it's 0.005 or 0.01mm depending on your motors. With 20 tooth pulleys you get 0.00625 or 0.0125mm.
Edited 1 time(s). Last edit at 01/03/2017 03:30PM by dc42.
January 03, 2017 03:35PM
Yeah I definitely prefer them with 0.9 degree motors,but this combination certainly requires the improved processing power of 32 bit boards. Plan to move to 0.9 degree motors on the corexy too trying the rearm board.
Simon Khoury
January 03, 2017 03:39PM
Cool, would love to go for 16 tooth then! Does anyone know if the corner pieces (2040 ones) from Robotdigg come with idlers for 16 or 20 tooth pulleys?
January 03, 2017 03:41PM
My Chinese copies of them come with smooth 16t diameter idlers so possibly.
Simon Khoury
January 03, 2017 03:47PM
I know it's not really the topic here, but do you think there is an advantage in using an idler with teeth instead of a smooth one and running the back (twisting) of the belt on it?
January 03, 2017 04:15PM
If you put the twist below the carriage down to the drive pulley this should work but you'll need to ensure if your carriages have toothed belt grips that they face the right way.
I'm running the toothed side of the belt over the idler whether this is detrimental to print quality or not is hard to tell if it is, it's marginal.
This is the sort of print quality it's turning out
I tried flanged toothed idlers on my kossel mini, I'd say probably noisier and the belt seemed to bump over the teeth and interfere with the flanges.
Edited 1 time(s). Last edit at 01/03/2017 04:16PM by DjDemonD.
Simon Khoury
January 03, 2017 04:33PM
I see, weren't you running twisted belts on your large kossel before? I thought I saw that in your build log?
January 03, 2017 05:11PM
Yes but I changed carriages from metal k800 to printed Haydn magnets and the belt grips are the "normal" way around.
Simon Khoury
January 03, 2017 05:27PM
This is how it currently looks.
Simon Khoury
January 03, 2017 07:53PM
Andreas15
When I first built my mini, I twisted the belt and had the smooth side running over the smooth idler.
Then I went to linear rails, and due to the carriage design had to remove the twist. I can't say that I notice the belt teeth in the print, but I have a set of toothed idlers sitting here that will be installed in the next few days. There is a resonance in my frame which means that I can't print at over 50 mm/s without seeing the vibrations in my print (and hearing the loud resonance). Whether this is due to the toothed belt running over the smooth idler, or something to do with my motors I can't say.
Interesting that DJDemonD had issues with those toothed idlers. I'll see how they go on my mini.
January 03, 2017 08:06PM
They might have been (were) cheap badly made idlers.
Simon Khoury
January 04, 2017 04:24AM
dc42
Is that really an advantage?
I know from gearboxes, that they intentionally use gears with prime numbers. ( eg,17 tooth ) Don't know, if there are similar effects seen with belts'n pulleys, but it would be worth trying 17 toothed pulleys.
Has anyone seen herringbone belts and pulleys?
January 04, 2017 04:58AM
Why do they use gears with prime numbers?
Simon Khoury
January 04, 2017 08:56AM
o_lampe
dc42
Yes it is you can step one microstep at a time for Calibration purposes much easier with they come out at a nice even number jogging the head .01 mm is possible with 16 tooth pulley but not with 17 or 20 for that matter
Doug
January 04, 2017 10:23AM
OK, I see the benefit during calibration.
Using prime numbers in gears means, you'll NEVER have a repeating pressure pattern. That leads to a more even wear on the teeth and prevents damages.
Worst case would be: every time a cylinder fires, the same tooth is on duty.
Having a belt/step ratio with even numbers means, you probably see repeating patterns on the print.
Many people use toothed idler bearings, because the belt rolls smoother.
Using 17 toothed pulleys falls in the same category.
Edited 1 time(s). Last edit at 01/04/2017 10:25AM by o_lampe.
