Removing vertical lines on prints April 23, 2017 08:48AM |
Re: Removing vertical lines on prints April 23, 2017 08:48AM |
Re: Removing vertical lines on prints April 23, 2017 08:49AM |
Re: Removing vertical lines on prints April 23, 2017 08:50AM |
Re: Removing vertical lines on prints April 24, 2017 09:05AM |
Re: Removing vertical lines on prints April 25, 2017 07:40AM |
Re: Removing vertical lines on prints April 25, 2017 10:50AM |
paboman
very interesting, will try that numbers on my smoothie.
did you noticed any improvement using anything beyond a4988 ?
Re: Removing vertical lines on prints April 26, 2017 12:18PM |
Re: Removing vertical lines on prints April 26, 2017 08:46PM |
DjDemonD
I'll try to get few cubes printed on the micro delta now its back together after failed attempt to use tmc2100s, now back using A4988s so testing the rosc mod should be quite doable. It's still running off good old ramps.
Re: Removing vertical lines on prints April 27, 2017 09:51AM |
Re: Removing vertical lines on prints April 27, 2017 10:23AM |
Re: Removing vertical lines on prints April 27, 2017 12:58PM |
Re: Removing vertical lines on prints April 27, 2017 02:13PM |
Re: Removing vertical lines on prints April 27, 2017 07:50PM |
Re: Removing vertical lines on prints April 27, 2017 09:38PM |
Re: Removing vertical lines on prints April 28, 2017 09:26AM |
Re: Removing vertical lines on prints April 28, 2017 11:35AM |
Re: Removing vertical lines on prints April 29, 2017 09:16AM |
Re: Removing vertical lines on prints April 29, 2017 09:47AM |
DjDemonD
No problems, what is your analysis of them?
Re: Removing vertical lines on prints April 29, 2017 10:35AM |
Re: Removing vertical lines on prints May 01, 2017 02:38AM |
Re: Removing vertical lines on prints May 01, 2017 06:12AM |
Re: Removing vertical lines on prints May 01, 2017 06:21AM |
Re: Removing vertical lines on prints May 01, 2017 09:45AM |
Re: Removing vertical lines on prints May 01, 2017 10:15AM |
Re: Removing vertical lines on prints May 02, 2017 03:32AM |
Re: Removing vertical lines on prints May 02, 2017 03:43AM |
