Re: FA-MAS mostly metal delta build - AKA Metal Gear November 10, 2017 05:16PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 11, 2017 03:36AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 11, 2017 09:05AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 11, 2017 09:44AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 11, 2017 10:00AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 11, 2017 10:14AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 11, 2017 10:16AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 11, 2017 10:52AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 11, 2017 10:58AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 11, 2017 11:03AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 11, 2017 11:11AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 11, 2017 12:59PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 11, 2017 02:13PM |
FA-MAS
These motors should work right? Same as ones DJDemonD posted, but higher Amp, lower Phase Resistance and Inductance.
https://www.omc-stepperonline.com/hybrid-stepper-motor/nema-17-bipolar-09deg-46ncm-651ozin-2a-28v-42x42x48mm-4-wires-17hm19-2004s.html?search=17HM19-2004S
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 11, 2017 02:15PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 11, 2017 04:05PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 13, 2017 06:03PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 14, 2017 04:36PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 14, 2017 04:52PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 14, 2017 05:08PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 15, 2017 01:33PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 15, 2017 02:22PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 16, 2017 12:01PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 16, 2017 12:21PM |
dougal1957
you will not be able to get the lengths spot on if you thread them so go for 4mm ID tude and epoxy the screws in after attaching the Rod ends so that you can get them the same length
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 16, 2017 12:26PM |
firefly555
Yup, threading things together will make it impossible to get the all the lengths the same and have the rod ends face the same direction. Just rough up the side of the tube, use a jig, and epoxy everything together.
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 16, 2017 12:49PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 17, 2017 11:16AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 17, 2017 11:20AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 17, 2017 11:49AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 17, 2017 12:04PM |
; Configuration file for Duet WiFi (firmware version 1.17 to 1.19) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool on Fri Nov 10 2017 13:27:35 GMT-0800 (PST) ; General preferences M111 S0 ; Debugging off G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M555 P2 ; Set firmware compatibility to look like Marlin ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration. M665 R164 L334 B75 H270 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them M208 Z0 S1 ; Set minimum Z ; Endstops M574 X2 Y2 Z2 S1 ; Define active high microswitches ;M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds ;G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height ;M557 R75 S20 ; Define mesh grid M558 P0 ; Set probe type to no probe, remove after probe is installed ; Drives M569 P0 S0 ; Drive 0 goes forwards M569 P1 S0 ; Drive 1 goes forwards M569 P2 S0 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X200 Y200 Z200 E837 ; Set steps per mm M566 X1000 Y1000 Z1000 E100 ; Set maximum instantaneous speed changes (mm/min) M203 X7200 Y7200 Z7200 E7200 ; Set maximum speeds (mm/min) M201 X3000 Y3000 Z200 E200 ; Set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Heaters M143 S290 ; Set maximum heater temperature to 290C M140 H-1 ; Disable heated bed M305 P1 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 1 ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Network M550 PMy Printer ; Set machine name M552 S1 ; Enable network ; Access point is configured manually via M587 by the user M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Fans M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Custom settings are not configured
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 17, 2017 03:50PM |
