Halo All,
I am now testing my J-Head MK V (bought from hotends.com) on Gen7 1.4.1 + Teacup and puzzled with this issue:
Suppose I heat the hotend to, for example, 80 deg, I notice the extruder led lights up until it read around 80 deg and turn off, but the hotend temp is not stay constant around 80 instead it keeps going up until 88 or event 90+ the slowly drops until around 79, then the lights up again for few seconds and stops when 80 deg reached. Again it still going up to around 90 deg.
This case happen for others temp setting. It somehow overshoots like 8 to 10 deg from target temperature.
I expect if I set the hotend temp 200 then it stays around 200. Temp_hysteresis set to 3. Please advice what needs to be done.
