Gen7 "Connecting..." problem December 12, 2014 07:09PM |
\0x00start echo: External Reset Marlin 1.0.0 echo: Last Updated: Dec 12 2014 21:07:30 | Author: (none, default config) Compiled: Dec 12 2014 echo: Free Memory: 13513 PlannerBufferBytes: 1232 echo:Hardcoded Default Settings Loaded Error:0 : Extruder switched off. MINTEMP triggered ! Errorrinter stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
Re: Gen7 "Connecting..." problem December 15, 2014 08:45AM |
zayoo
When I connect Gen7 directly over serial terminal port (CuteCom) and reset board i get:
\0x00start echo: External Reset [...]
zayoo
I notice when I establish connection over serial terminal and then start Prontface connection is done. And then I can control my board over Printrun.
Does anybody have or had similar problems?
I found on internet that some "sleep times parameters" in Printrun scripts should be changed but i can't find this parameters in my version of Printrun.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Gen7 "Connecting..." problem December 15, 2014 12:12PM |
Connecting... SENT: M105 SENT: M105 SENT: M105 SENT: M105 SENT: M105 SENT: M105 SENT: M105 SENT: M105 Reset. SENT: M105 SENT: M105 SENT: M105 SENT: M105 Reset. SENT: M105 SENT: M105
Re: Gen7 "Connecting..." problem December 15, 2014 12:41PM |
Re: Gen7 "Connecting..." problem December 15, 2014 01:47PM |
Re: Gen7 "Connecting..." problem January 05, 2015 10:31AM |
Re: Gen7 "Connecting..." problem January 06, 2015 07:40AM |
Re: Gen7 "Connecting..." problem March 27, 2015 04:57PM |
