UDOO-NEO
Posted by unarmedrob
UDOO-NEO
April 22, 2015 12:24PM
Arduino and Raspberry Pi combined, and only $35 on Kick-starter.
Just posting to get peoples general consensus on the device. Would it be capable of running a reprap? Maybe with its own webserver?
[www.udoo.org]
Re: UDOO-NEO
April 22, 2015 12:47PM
Looks interesting, although the potential problem with anything running Linux is to get good enough real-time performance. It's generally preferable to offload the hard real-time stuff to a separate processor. What would be really interesting is to take the 4-core Raspberry Pi, hand 3 cores over to Linux, and dedicate one to the real time stuff.
You can already get 3D printer controller boards that run web servers, e.g. Duet and Smoothie. I think the real benefit of attaching something as powerful as the RPi to a 3D printer is if you want to add streaming video, or do slicing on it as well.
Edited 1 time(s). Last edit at 04/22/2015 01:13PM by dc42.
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
Re: UDOO-NEO
April 22, 2015 01:21PM
dc42
If you look at the design uses a Freescale™ i.MX 6SoloX with an embedded ARM Cortex-A9 core and a Cortex-M4 Core where the Cortex-A9 is used for the Linux system and the Cortex-M4 is used for the Real-time Arduino processing.
Re: UDOO-NEO
April 22, 2015 01:25PM
It's got a Cortex A9 to run the Linux and a Cortex M4 pretending to be an Arduino to do the real time stuff.
Re: UDOO-NEO
April 22, 2015 01:30PM
Ah, that makes a big difference then!
Re: UDOO-NEO
April 22, 2015 01:57PM
It's a great solution to run OctoPrint on the Cortex-A9 and any of the available 32-bit firmwares on the Cortex-M4. thumbs up
I would really like to see a cape/RAMPS style board developed for it! smiling bouncing smiley
Re: UDOO-NEO
May 15, 2015 05:21AM
Have you seen that the RADDS is being sold bundeled with the UDOO-Neo?
I wonder how the software solution looks like for it. Can´t be that complicated, but how does the Linux platform connect to the integrated arduino due? Virtual USB?
VDX
Re: UDOO-NEO
May 15, 2015 07:16AM
... yes, it's 'communicating' via a serial bus, so no big difference to a sseparate linux-quadcore and an ArduinoDue connected by a cable ...
Viktor
Aufruf zum Projekt "Müll-freie Meere" - [reprap.org]
Re: UDOO-NEO
May 15, 2015 08:06AM
Yellobello
I had not seen that! Nice! So it seems they already have a complete firmware solution worked out. thumbs up
Re: UDOO-NEO
May 15, 2015 09:18AM
@Yellobello, where have you seen the UDOO-Neo bundled with RADDS?
Isn't RADDS a Due sheild, i.e. same pinout as Arduino Mega? But Neo is the smaller pinout like an Arduino Uno. Is it compatible?
Edited 1 time(s). Last edit at 05/15/2015 09:18AM by nophead.
VDX
Re: UDOO-NEO
May 15, 2015 12:11PM
... the UDOO has the same pins/sockets footprint as the ArduinoDue, so the RADDS will fit to it too (I have both types here - RADDS with Due and with UDOO).
But AFAIK, the UDOO-Neo has another pin arrangement, so not compatible with the RADDS ...
Viktor
Re: UDOO-NEO
May 17, 2015 03:47AM
Sorry my fault!
Just another fancy namy hiccup on my list!
the UDOO is not the UDOO-neo, off course!! How could I forget that?
[max3dshop.org]
AND I have to adidmit that I already came as far as figuring out that the board should not be able to fit, but then thought "voodoo!"
Edited 1 time(s). Last edit at 05/17/2015 03:49AM by Yellobello.
