Re: Generation 7 Electronics Development January 23, 2013 01:39PM |
Re: Generation 7 Electronics Development January 24, 2013 07:30AM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Generation 7 Electronics Development January 24, 2013 12:36PM |
Re: Generation 7 Electronics Development February 08, 2013 09:55PM |
Re: Generation 7 Electronics Development February 09, 2013 07:05AM |
Re: Generation 7 Electronics Development February 10, 2013 02:03AM |
Re: Generation 7 Electronics Development February 12, 2013 05:23PM |
and everything seems to be fine..well not everything.|
Re: Generation 7 Electronics Development February 12, 2013 05:56PM |
Re: Generation 7 Electronics Development February 13, 2013 05:37AM |
JP.Ruiz
At the moment this is the situation, I CAN'T upload the code to ATmega1284 by USB but I CAN upload the firmware (Teacup) by USBTiny and use GEN7 1.5 normally.
bobc
Video of Gen7-ARM in action [youtu.be]
Re: Generation 7 Electronics Development February 13, 2013 08:58AM |
Re: Generation 7 Electronics Development February 14, 2013 06:21AM |
Re: Generation 7 Electronics Development February 14, 2013 09:16AM |
Re: Generation 7 Electronics Development February 20, 2013 10:02PM |
Re: Generation 7 Electronics Development February 21, 2013 06:09PM |
Re: Generation 7 Electronics Development February 22, 2013 05:44AM |
Re: Generation 7 Electronics Development February 22, 2013 07:13AM |
Re: Generation 7 Electronics Development February 22, 2013 08:20AM |
I have built a slightly larger mendelmax model 300x300 and I am thinking of using a homemade PCB heated bed (400W), the ones online as too small for the bed. My question is, is it possible to connect a heated bed to the gen7 electronics to to control it and power the board seperatly or can I connect 2 power supplies to the gen7 to get the extra power required? gen7 can handle 30A?
Perhaps its easier to look for 1 powerful 24V supply rather than 2 12V supplies, can I use a 24V supply on gen7?
If you used 2, 12V supplies how would they be connected. Must the supplies be the same voltage?
Re: Generation 7 Electronics Development February 23, 2013 07:44PM |
Re: Generation 7 Electronics Development February 24, 2013 09:16AM |
Re: Generation 7 Electronics Development February 25, 2013 07:58AM |
Traumflug
Sure you can make that extension board footprint smaller. You'll loose compatibility with standard sized ones, of course. You can even drop it entirely, it's not essential.
Traumflug
When I made that EB-footprint I'd have loved to have a crystal ball to look a bit into the future to see what it's used for.
Re: Generation 7 Electronics Development February 26, 2013 04:02PM |
Re: Generation 7 Electronics Development February 26, 2013 10:06PM |
Traumflug
Looks excellent, Xoan!
Congratulations!
Traumflug
> 2. Endstop connector pins are mirrored, so signal is now 5V and 5V is now signal.
Could be solved by turning them 180° ? Doesn't matter much if you do the cabling yourself, though.
Traumflug
> 3. Axis (and extruder) connectors must be right angle or standar 4 pin header.
To me it looks like they overlap with the Pololus, but I guess you know what you're doing.
Re: Generation 7 Electronics Development February 28, 2013 04:23PM |
Re: Generation 7 Electronics Development March 01, 2013 08:11AM |
Re: Generation 7 Electronics Development March 01, 2013 08:57AM |
Traumflug
There has to be a distinction between the GND track going to the MOSFETs and the one going to the thermistor connectors. As they're currently drawn they likely connect to each other when using Visolate. Extending one of the nearby tracks to fill some of the room between both ends of the huge GND track should help.
Traumflug
What's the purpose of all this (I'm just curious) ? Are there printers where a 100 mm wide PCB doesn't fit, but a 80 mm wide one does? And how how do the overlapping connectors fit there? Would a 80 mm x 140 mm board fit there, too?
Re: Generation 7 Electronics Development March 01, 2013 09:32AM |
Re: Generation 7 Electronics Development March 07, 2013 09:27AM |
Rezer
If the USB is unplugged after that and plugged back in you have to power cycle the board, wait for the caps to discharge, and plug it back in. I'm assuming this is a side effect of powering the MCP2200 from the board instead of the usb port and not shoddy soldering on my part, but I'm less than 100% positive on that one. Is this expected behavior?
[140023.076106] usb 2-1: new full-speed USB device number 15 using ohci_hcd [140023.284716] cdc_acm 2-1:1.0: This device cannot do calls on its own. It is not a modem. [140023.284759] cdc_acm 2-1:1.0: ttyACM0: USB ACM device [140023.304424] hid-generic 0003:04D8:00DF.0010: hiddev0,hidraw3: USB HID v1.11 Device [Microchip Technology Inc. MCP2200 USB Serial Port Emulator] on usb-0000:00:03.0-1/input2 [140041.553843] usb 2-1: USB disconnect, device number 15 [140045.582772] usb 2-1: new full-speed USB device number 16 using ohci_hcd [140045.791342] cdc_acm 2-1:1.0: This device cannot do calls on its own. It is not a modem. [140045.791387] cdc_acm 2-1:1.0: ttyACM0: USB ACM device [140045.811079] hid-generic 0003:04D8:00DF.0011: hiddev0,hidraw3: USB HID v1.11 Device [Microchip Technology Inc. MCP2200 USB Serial Port Emulator] on usb-0000:00:03.0-1/input2
Re: Generation 7 Electronics Development March 07, 2013 10:42AM |
peter6960
- ATX24 and 4 ways on different sides of board. So no matter how you try the thicker PSU cables has to ho over or under the PCB or other wires. If someone finds away to put all power circuitry to one side, wiring would be a dream
peter6960
- mcp2200 reset. The reenumaration dance gets less exciting as time goes on
- reset switch. Behind USB socket = very difficult to reach in emergency or otherwise. Move it closer to board edge
Re: Generation 7 Electronics Development March 08, 2013 02:37AM |
