Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 28, 2015 08:07PM |
theothermike
Go ahead with controllers you´re feeling most comfortable. ;-)
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 29, 2015 06:10AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 29, 2015 09:14PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 30, 2015 05:23AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 30, 2015 05:41AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 30, 2015 06:57AM |
realthor
I'm a noob at everything here, am quite surprise I can still swim through all this
realthor
Please let me know if there is any success with the teacup SCARA. I am mostly interested in that.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z June 30, 2015 09:20AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 01, 2015 09:26AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 01, 2015 10:04AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 16, 2015 12:23PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 23, 2015 12:47PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 23, 2015 03:26PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 24, 2015 05:22AM |
realthor
waiting for some coding wizard to put that into firmware
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 24, 2015 08:41AM |
Traumflug
realthor
Why would a developer do this? You created the trivial part, the mechanics, now it's time to approach the challenge. Regarding Teacup I'd start with turning on debugging messages in dda_create() to see which movements come in, to how many steps this is translated and what the timings are (dda->c, dda->c_min = time distance in CPU clocks between two steps of the fastest axis).
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 24, 2015 10:22AM |
realthor
Because the "trivial" mechanical design is pretty much where my knowledge/skills stops, if at that.
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 24, 2015 10:29AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 24, 2015 10:52AM |
realthor
Does your boat have enough time for learning coding?
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 31, 2015 11:05AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 31, 2015 12:44PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 31, 2015 01:43PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 31, 2015 04:13PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 31, 2015 04:32PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 31, 2015 05:31PM |
realthor
how much do you think they will shrink?
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 31, 2015 05:35PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z July 31, 2015 05:49PM |
realthor
I don't dare to warm that up it will just become gelatine.
realthor
Warming the bearing housing makes sense too ...
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z August 01, 2015 01:01PM |
realthor
The problem with stacking everything up is that bearings will never go perfectly vertically in the hole, they will go into an angle with the increasing pressure and that might crack the plastic. Having it from the freezer might help.
Wobble will not ruin the printer ... I believe it will have a small toll on accuracy (whichever that is).
Heating bearings?!!
For my setup I need a shaft/rod/bolt/etc that is threaded at the ends so I can clamp down the stack. M8 standard is actually less than 8mm by quite a bit. But I don't thik that will pose major problems because as the tensioning spectra will pull the drum towards the bolt on the motor, the bearing will sit against the same side of the shaft/rod and that will only decrease my arm length by 0.2mm maybe. The tension will always keep it there.
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z August 01, 2015 01:22PM |
cozmicray
Work on the code
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z August 01, 2015 05:04PM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z August 02, 2015 04:16AM |
Re: started designing a new mostly-plastic reprap SCARA with fishing line motion transmission and unorthodox winch for Z August 02, 2015 05:18AM |
