reprap driver using IC l297 and l298
Posted by learner_m
February 05, 2014 05:13AM
hellow every one!
i am new in this reprap forum.
> I am building reprap 3d printer.
> I found difficulty in availability of stepper drivers in my country so i construct them with the help of IC l297 and l298 by using following reprap link .
[reprap.org]
Now i have two problems:
1) how to connect these drivers with ramps 1.4.
2) what rating of power supply should i use?
i will be very thankful if any one help me out on this problem.
Waiting for your soonest reply!!
Re: reprap driver using IC l297 and l298
February 07, 2014 08:54AM
just connect the enable, direction and step pins from the ramp board to the corresponding pins on your driver board... also if possible try to look for a tb6560 based driver board as this driver based on the l297 and l298 is outdated and will not give you quality prints as it only supports 1/2 stepping and you need a minimum of 1/8 stepping for a decent print , also your printer will be very noisy....
best way is to source the pololus from ebay.... it will save you a lot of head and heart aches
February 11, 2014 01:35PM
thanks ekaggrat !!!
your comment help me a lot.
February 12, 2014 12:07AM
dear friend ekaggrat ,
some people use T5 timing belt and some use T2.5. Does it requires any change in firmware?
waiting for your reply!
February 14, 2014 04:22AM
t2.5 or gt2 or s2m are all ok avoid the t5 .....
