Re: CoreXZ October 04, 2014 12:18PM |
Re: CoreXZ October 04, 2014 08:32PM |
Re: CoreXZ October 05, 2014 08:18PM |
Re: CoreXZ October 11, 2014 10:47PM |
Re: CoreXZ October 13, 2014 01:57AM |
Re: CoreXZ November 02, 2014 11:32PM |
Re: CoreXZ November 06, 2014 12:02PM |
Re: CoreXZ November 06, 2014 12:13PM |
Re: CoreXZ November 08, 2014 01:04PM |
Re: CoreXZ November 20, 2014 08:30AM |
Re: CoreXZ December 09, 2014 10:17AM |
Re: CoreXZ December 09, 2014 02:37PM |
Re: CoreXZ December 09, 2014 04:12PM |
Re: CoreXZ December 11, 2014 10:57AM |
There are lots of ways to reduce width but as DaveGadgeteer mentioned you want to keep the lines vertical. Imagine doing a 90 degree fold along the z axis. I kept it all flat in one plane for simplicity. Width isn't really a problem. It is about as wide as most 200mm printers would be.Quote
tulindo
* In order to reduce the width of the X (having the same printable area) do you think it is possibile to bring bearings close to each other? (like in my attached file)... I don't se any drawbacks in doing this, do you?
I just like the 625VV better. The 623VV or 624VV bearings would be great. The 625VV bearings are actually thinner in their axial direction. 625VV can also use normal washers for spacers unlike the others. At the end of the day, they are all good.Quote
tulindo
* You used 625VV bearings... any disadvantages in using little ones (like 624VV)? They should be cheaper (and also will nuts, bolts, washers will be cheaper)...
PM your email and I will send you my hackish MarlinXZ.Quote
tulindo
* As far as I have understood you developed a new firmware in order to drive the printer... any info?
I use a RAMPS-like controller.Quote
tulindo
* Electronics: does your corexz rely on the standard arduino mega / ramps to do the magic?
Most any should work. You will have to figure out how to mount it so pick one that you like the form factor. For me, they are too long so I have to do lots of work to get the tension area in the right spot.Quote
tulindo
* I like very much the use of guitar tuning peg to tension the strings... will any standard guitar peg works or I've to look for special characteristics? Which one did you use?
Re: CoreXZ January 06, 2015 06:00AM |
Re: CoreXZ January 06, 2015 01:53PM |
Re: CoreXZ February 09, 2015 09:47PM |
Re: CoreXZ February 10, 2015 11:43AM |
SydneyDesigner
Thanks to everyone for their contributions to this fascinating and informative topic. I'm particularly interested to hear what seems to be very successful uses of spectra/fishing line.
My basic question is this. Is the consensus that (with good design) spectra/fishing line for X, Y and Z gives similar (or perhaps even better?) print precision and speed as GT2 belts?
I'm not building a CoreXZ so sorry for being a bit OT. My plan is: for X&Y either CoreXY or DW-G (still deciding pros/cons) driven by line; Z lifted in 4 corners by line & pulleys too (can this be designed accurate enough compared to belt-driven lead screws?); 400-500mm cubish build area; enclosed to run up to about 80C; based on V-slot with wheeled carriages.
I would be grateful for any suggestions please.
wikipedia
It is not advisable to use UHMWPE fibers at temperatures exceeding 80 to 100 °C (176 to 212 °F) for long periods of time.
Re: CoreXZ February 12, 2015 06:02AM |
nicholas.seward
I tend to think that fishing line belongs on small to medium sized printers. I would classify yours as a large printer.
Re: CoreXZ February 12, 2015 10:22AM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: CoreXZ February 12, 2015 11:29AM |
Re: CoreXZ February 13, 2015 06:54AM |
Re: CoreXZ February 13, 2015 11:52AM |
Re: CoreXZ February 13, 2015 02:24PM |
Re: CoreXZ February 14, 2015 07:33AM |
Re: CoreXZ February 18, 2015 02:50PM |
Re: CoreXZ February 18, 2015 03:08PM |
robomaster
I am experimenting with corexz, but as I research Spectra line it appears that it has a problem called "creep" where it elongates when held under tension over time. For this reason they don't like to use it for standing rigging on performance sailboats, but use Kevlar or Vectran instead. I don't want to have to re-tension and re-level my printer after I have gone some time without using it. Has anyone experienced this problem?
I was thinking of using Kevlar, but it supposedly has more problems with abrasion and fatigue. Vectran seams to be be perfect on paper as it has lower creep and better abrasion resistance. Has anyone tried either of these fibers and are there any problems I should know about before I buy some?
I am planing on experimenting with 120lb test Kevlar with PTFE coating available from twinline for $6.75. The other option is 80 or 200 lb. Vectran available in 250 fl spools for $5 or $30 respectively.
Re: CoreXZ February 19, 2015 05:16PM |
Re: CoreXZ February 19, 2015 05:24PM |
robomaster
Thanks for the answer. I teach a high school physics class, so I think I will test these fibers as an example science project next year. I just need to find some good suppliers that have genuine materials for cheep. Does anyone know what brands/suppliers of Spectra are most commonly used for 3D printers?
