Heat Compensated Bed Support First Test February 08, 2016 11:00PM |
Re: Heat Compensated Bed Support First Test February 09, 2016 06:42AM |
Re: Heat Compensated Bed Support First Test February 09, 2016 12:02PM |
Re: Heat Compensated Bed Support First Test February 10, 2016 09:05AM |
Re: Heat Compensated Bed Support First Test February 10, 2016 01:02PM |
Re: Heat Compensated Bed Support First Test February 10, 2016 01:23PM |
Re: Heat Compensated Bed Support First Test February 10, 2016 01:37PM |
Re: Heat Compensated Bed Support First Test February 10, 2016 01:51PM |
Re: Heat Compensated Bed Support First Test February 10, 2016 01:54PM |
Re: Heat Compensated Bed Support First Test February 10, 2016 02:14PM |
Re: Heat Compensated Bed Support First Test February 10, 2016 02:48PM |
Re: Heat Compensated Bed Support First Test February 11, 2016 12:30AM |
Re: Heat Compensated Bed Support First Test February 11, 2016 02:03AM |
Re: Heat Compensated Bed Support First Test February 11, 2016 06:00AM |
Re: Heat Compensated Bed Support First Test February 27, 2016 08:10PM |
Re: Heat Compensated Bed Support First Test February 27, 2016 08:25PM |
Re: Heat Compensated Bed Support First Test February 27, 2016 09:52PM |
Re: Heat Compensated Bed Support First Test February 28, 2016 01:43AM |
JamesK
The idea of doing away with the carriage once you have a sufficiently stiff bed is brilliant, but, if I understand correctly, all of the bed acceleration now has to be transmitted from the motor to the bed via a single mounting screw - the reference screw in your original description. Have you had to beef up that mounting point to cope with the load?
MechaBits
the 2 attachment points on the center line, I know the idea is for them to be able to move apart, they are tied with the bed, I wonder if they could be tied to each other, more even distribution of the drive power(just my thoughts, maybe not correct), but put another slide dovetail under the bed between adjuster, like you have on the side.
Re: Heat Compensated Bed Support First Test February 28, 2016 05:05AM |
Re: Heat Compensated Bed Support First Test February 28, 2016 07:07AM |
Re: Heat Compensated Bed Support First Test February 28, 2016 09:08AM |
Re: Heat Compensated Bed Support First Test February 28, 2016 10:57AM |
Re: Heat Compensated Bed Support First Test February 28, 2016 11:45AM |
Re: Heat Compensated Bed Support First Test February 28, 2016 12:53PM |
amigob
I was wondering why you still use the spring mounts.
If I understand the design correctly, then the system you now have will completely handle the
expansion. So you can make the rest of the mountings 100% rigid.
I like the idea and I think I will also try this on my P3Steel when everything is working.
Directly mount an aluminum heat bed to the linear bearings on one side, little bit bigger distance between the bearings then default. And on the other side use the linear ball bearing guide rail, to handle the X expansion, mounted in the middle of the headbed to 2 linear slide bearings of the Prusa.
Re: Heat Compensated Bed Support First Test February 28, 2016 01:14PM |
JamesK
It's far from a bad result for a completely new approach - especially one that has removed a whole load of mass from the Y axis.
Re: Heat Compensated Bed Support First Test February 29, 2016 11:18PM |
Re: Heat Compensated Bed Support First Test March 01, 2016 07:48AM |
Re: Heat Compensated Bed Support First Test March 01, 2016 09:15AM |
Re: Heat Compensated Bed Support First Test March 02, 2016 12:52AM |
Re: Heat Compensated Bed Support First Test March 04, 2016 06:26PM |
