Hello,
I am building a simple bot using Marlin Firmware and TMC2209 stepper motors. This machine runs the X, Y and Z axis and it's purpose is simply to dispense glue. My issues is that for some reason when I insert an SD card and select a simple g-code program it will run the homing for X, Y and Z, but then commences to only run the Z axis, X and Y will not move. This is frustrating as when I connect to pronterface everything works fine all axis respond. I have tried a myriad of different g codes and sequences and every time it's the same, everything will home, but only the z will run. I have attached my modified Marlin config files along with a one code I've tried to run. I have read through a many different forums, but haven't found any solutions. I have tried using the 998 and 999 dummy thermistors, and have played with the feed rates.
Thank you in advance!
