Huxley dual extruder upgrade ?
May 27, 2014 05:39AM
Could we imagine to replace the extruder by a duel extruder on reprappro Huxley ?
Did someone try something similar ?
I would like to use PVA soluble material to build supports.
Fuji
Edited 1 time(s). Last edit at 05/27/2014 05:39AM by fujisama.
Re: Huxley dual extruder upgrade ?
May 29, 2014 07:01AM
How about [www.thingiverse.com]
Ian
RepRapPro tech support
June 01, 2014 06:45AM
Do you think that's possible with:
- Huxley dual nozzle holder or RepRapPro Dual Hotend
- Sanguinololu Upgrade Module, is it compatible with marlin ?
- Slic3r to generate the g-code
my confg is:
RepRapPro Huxley
Snguinololu 1.3a
Marin 1.01
June 01, 2014 07:05AM
Hum, I don't think the SLUM project was completed,
Maybe I can use my old Sanguinololu PCB to act as a stepper expansion board like here: http://richrap.com/?p=121
Did someone tried to use 2 nozzles in one hotend to manage just on temperature hotend with two material ?
Edited 1 time(s). Last edit at 06/01/2014 07:25AM by fujisama.
June 02, 2014 07:55AM
I think the Huxley hot-end will easily support a second nozzle, without extending the carriage, which would seriously limit the X movement.
Might require also a bigger heatsink or using a late to adjust the thickness of the nozzle between the hot and cold end.
In case of the Melzi board, the unused heated bed driver could be used to control the second resistor/cartridge.
The AUX header has enough pins to drive an additional stepstick.
I didn't experiment it yet, but I think it could be an interesting opportunity smiling smiley
May 25, 2015 07:46AM
I have a reprap(pro) huxley with melzi and I would really like to be able to use dual extruders, to use PVA supports, t'he heated bed unused connector seems like a great idea!
For the heatsink, a cut old CPU heatsink might be enough, I think the marlin software does support dual extruders.
If It can't, we could use a slave melzi or an arduino to control de 2nd extruder.
