How to wire PS-ON to control PC Power Supply? May 13, 2012 09:18PM |
Re: How to wire PS-ON to control PC Power Supply? May 14, 2012 12:05AM |
Re: How to wire PS-ON to control PC Power Supply? May 18, 2012 12:27PM |
Re: How to wire PS-ON to control PC Power Supply? May 22, 2012 11:24AM |
Re: How to wire PS-ON to control PC Power Supply? May 23, 2012 05:02AM |
Does the ATX PSU provide enough standby power to keep the Arduino awake
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: How to wire PS-ON to control PC Power Supply? May 23, 2012 01:29PM |
Re: How to wire PS-ON to control PC Power Supply? May 24, 2012 07:32AM |
Re: How to wire PS-ON to control PC Power Supply? May 24, 2012 10:41AM |
Re: How to wire PS-ON to control PC Power Supply? May 24, 2012 10:48PM |
Re: How to wire PS-ON to control PC Power Supply? September 14, 2013 01:39AM |
Re: How to wire PS-ON to control PC Power Supply? September 14, 2013 04:25AM |
Re: How to wire PS-ON to control PC Power Supply? April 10, 2014 09:27PM |
rmm200
Johnnyr (good man) got in touch with me and got me straightened out. He also updated the WIKI with more info, so rather than quote him I will just direct future callers there...
Re: How to wire PS-ON to control PC Power Supply? April 10, 2014 09:30PM |
Re: How to wire PS-ON to control PC Power Supply? April 11, 2014 07:58AM |
Re: How to wire PS-ON to control PC Power Supply? May 02, 2014 09:12PM |
Re: How to wire PS-ON to control PC Power Supply? May 02, 2014 10:35PM |
Re: How to wire PS-ON to control PC Power Supply? May 03, 2014 09:12AM |
swe3tdave
if the 5v standby of your psu is not powerfull enough, it might start to heat up, if that is the case, its possible that the fan would turn on automatically.
Do you have the specs of your power supply on the 5v standby? How many amps?
You could use a separate 5v power supply... Or just keep the usb connected...
Re: How to wire PS-ON to control PC Power Supply? May 03, 2014 11:31AM |
Re: How to wire PS-ON to control PC Power Supply? May 14, 2014 11:06AM |
CptanPanic
You misunderstood my question. I am not using the 5V standby to power arduino, but the USB. But am wanting to use the ATX power on feature to turn on the ATX power supply, which works as long as the arduino has power. But if I remove power to arduino by disconnecting USB, the ATX power supply tries to turn on. It looks like this PS_ON pin goes directly to the arduino, so is there anyway to fix this without having to keep arduino powered up all the time?
How to wire PS-ON to control PC Power Supply on Melzi board April 27, 2016 09:44PM |
Re: How to wire PS-ON to control PC Power Supply? August 09, 2016 02:20PM |
Re: How to wire PS-ON to control PC Power Supply? August 10, 2016 05:04AM |
Admin Registered: 13 years ago Posts: 7,003 |
Re: How to wire PS-ON to control PC Power Supply? August 10, 2016 04:25PM |
That is a shame, looking forward to adding an on/off switchQuote
Dust
No Monetary switch
mega has be powered on always
ramps is directly connected to green ATX wire to the PS-ON, this is pulled low by the mega via gcode
M80 ATX_Power_On
M81 ATX Power Off
[reprap.org] look at the bottom left panel "Power". D12 is connected to PS-ON
D12 is the pin, as defined by ardunio
[www.arduino.cc] you find that D12 is really PB6 ( OC1B/PCINT6 )
Here is the decoder ring [marcusjenkins.com]
Re: How to wire PS-ON to control PC Power Supply? May 02, 2017 04:29AM |
