Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch October 15, 2012 02:24AM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch October 15, 2012 04:49AM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch October 15, 2012 09:34AM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch October 19, 2012 02:02PM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch October 19, 2012 02:46PM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch September 30, 2013 10:47PM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch November 01, 2013 06:54AM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch November 02, 2013 02:08AM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 22, 2014 07:59PM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 22, 2014 08:47PM |
mrPrik
Blew up my arduino mega yesterday. bought some sainsmart mech endstops , four pin. Not much online about pin out but i decided from reading around it was 1 VCC 2 + 3 GND 4 SIG. taped back one 'gnd' and stuck the others into my ramps 1.4. did not check with a multimeter first. switch it on - nothing. no led light. I paused, switch in hand. hmm, should I click.. yeah I'm curious. BANG smoke comes out the side of the arduino mega. some transistors have burnt out. dont even know if my ramps board is ok.ffffffffffff
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 23, 2014 06:17AM |
the board matches the V1.0 endstop schematics and works when wired as per the sketch above. It passed the smoke check on my Megatronics V2.0 board (also with +, -, S pins), and the LED even lit up when the switch was pressed.....
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 23, 2014 10:12AM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 23, 2014 11:31PM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 24, 2014 07:35AM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 24, 2014 12:18PM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 27, 2014 01:38AM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 27, 2014 04:27AM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 27, 2014 05:50AM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 27, 2014 11:58AM |
CanCakes
Ah. I just found this:
[www.thingiverse.com]
The picture of the green circuit board on a blue background shows VCC, GND, and SIG pins are actually congruent with the FIRST picture that kenwilliams posted. [forums.reprap.org]
I think this might be the answer. Thoughts?
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 27, 2014 01:21PM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 27, 2014 02:20PM |
CanCakes
Pinout
PIN NAME FUNCTION
1 5V This pin provides 5V to the endstop switch.
2 GND This pin is connected to ground on the endstop.
3 GND This pin is connected to ground on the endstop.
4 SIGNAL This pin is the output of the endstop. LOW = endstop activated, HIGH = endstop normal.
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 27, 2014 04:44PM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 27, 2014 04:52PM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 27, 2014 05:13PM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 27, 2014 08:01PM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 27, 2014 08:28PM |
The way I approach Chinese stuff is that they provide cheap stuff that can be made into a useful item, and don't assume anything about what is delivered.|
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 27, 2014 08:52PM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 27, 2014 11:58PM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 28, 2014 02:53AM |
Re: Makerbot Endstops / Wiring Kit / RAMPS 1.4 mismatch January 28, 2014 06:17AM |
CanCakes
Although the board itself says v1.1, the page on thingiverse (http://www.thingiverse.com/thing:4971) is titled "Mechanical Endstop 1.2. And on the board, it says to refer to "wiki.makerbot.com/me1" for instructions. (I think the site doesn't exist anymore, is it down for everyone or just me?)
