Electronic disturbance (ground loop)?
Posted by zungmann
January 06, 2013 09:32PM
Halo,
I am building my first RepRap and now testing the electronic with RAMPS 1.4 and Gen7. I have issue with my RAMPS: once I turn on the PSU, my laptop start getting disturbed, its very difficult to control the mouse. If I turn the PSU off, its gone (although still connected to).
Any advice please what causing this and how to remove the disturbance?
Thanks.
Re: Electronic disturbance (ground loop)?
January 07, 2013 08:17AM
AFAIK, RAMPS doesn't properly distinguish between 5V from USB and its own 5V. Not sure how to fix it, though.
January 08, 2013 10:45PM
If you're only ever going to run your RAMPS connected to a PC (ie: no SD option), then remove the diode that feeds the regulator on the Arduino (D1 on the RAMPS board, under the X and Y steppers).
January 10, 2013 09:07AM
Ya, I am just going to use PC, no SD. I will try it, thanks Cefiar.
