Problem with Mosfets on RAMPS 1.4 board April 08, 2014 10:17AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 09, 2014 02:21AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 09, 2014 07:02AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 09, 2014 07:18AM |
olisoft
did you connect the power supply to both connectors on your ramps?
waitaki
The mosfets do not control the motors, the Pololu drivers do that. Also, those LED's belong to the heater, bed and fan circuit. Or am I misunderstanding you?
Re: Problem with Mosfets on RAMPS 1.4 board April 10, 2014 04:25AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 10, 2014 12:52PM |
Re: Problem with Mosfets on RAMPS 1.4 board April 10, 2014 11:43PM |
Re: Problem with Mosfets on RAMPS 1.4 board April 11, 2014 04:05AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 11, 2014 04:35AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 11, 2014 08:14AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 12, 2014 12:48PM |
Re: Problem with Mosfets on RAMPS 1.4 board April 13, 2014 02:02AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 14, 2014 10:42AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 15, 2014 02:07AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 15, 2014 02:43AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 15, 2014 10:41AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 16, 2014 05:57AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 17, 2014 06:03PM |
Re: Problem with Mosfets on RAMPS 1.4 board April 17, 2014 07:50PM |
Re: Problem with Mosfets on RAMPS 1.4 board April 19, 2014 12:24PM |
Re: Problem with Mosfets on RAMPS 1.4 board April 19, 2014 06:44PM |
Re: Problem with Mosfets on RAMPS 1.4 board April 20, 2014 05:18AM |
//// The following define selects which electronics board you have. Please choose the one that matches your setup // 3 = MEGA/RAMPS up to 1.2 = 3 // 33 = RAMPS 1.3 / 1.4 (Power outputs: Extruder, Fan, Bed) // 34 = RAMPS 1.3 / 1.4 (Power outputs: Extruder0, Extruder1, Bed) // 35 = RAMPS 1.3 / 1.4 (Power outputs: Extruder, Fan, Fan) #ifndef MOTHERBOARD #define MOTHERBOARD 35 #endif
Re: Problem with Mosfets on RAMPS 1.4 board April 21, 2014 01:06AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 22, 2014 05:39AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 22, 2014 07:50AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 22, 2014 11:05AM |
//// The following define selects which electronics board you have. Please choose the one that matches your setup // 3 = MEGA/RAMPS up to 1.2 = 3 // 33 = RAMPS 1.3 / 1.4 (Power outputs: Extruder, Fan, Bed) // 34 = RAMPS 1.3 / 1.4 (Power outputs: Extruder0, Extruder1, Bed) // 35 = RAMPS 1.3 / 1.4 (Power outputs: Extruder, Fan, Fan) #ifndef MOTHERBOARD #define MOTHERBOARD 35 #endif // Define this to set a custom name for your generic Mendel, //#define CUSTOM_MENDEL_NAME "" // Define this to set a unique identifier for this printer, (Used by some programs to differentiate between machines) // You can use an online service to generate a random UUID. (eg [www.uuidgenerator.net]) // #define MACHINE_UUID "00000000-0000-0000-0000-000000000000" // This defines the number of extruders #define EXTRUDERS 1 //// The following define selects which power supply you have. Please choose the one that matches your setup // 1 = ATX // 2 = X-Box 360 203Watts (the blue wire connected to PS_ON and the red wire to VCC) #define POWER_SUPPLY 1 // Define this to have the electronics keep the power supply off on startup. If you don't know what this is leave it. // #define PS_DEFAULT_OFF
Re: Problem with Mosfets on RAMPS 1.4 board April 23, 2014 01:11AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 23, 2014 08:38AM |
Re: Problem with Mosfets on RAMPS 1.4 board April 23, 2014 07:34PM |
Re: Problem with Mosfets on RAMPS 1.4 board April 24, 2014 04:53AM |
