XBox 360 PSU confusion May 27, 2014 06:47PM |
Re: XBox 360 PSU confusion May 27, 2014 07:17PM |
Re: XBox 360 PSU confusion May 27, 2014 10:50PM |
vreihen
The 11A circuit only feeds the heated bed. If you don't have one, you don't need to hook up the 11A power at all.
you might want to double-check your power budget math
Re: XBox 360 PSU confusion May 28, 2014 07:37AM |
.Quote
RepRap wiki
There are several versions, choose the 203W version. Note that the power may be insufficient for some heated beds. The PSU will shutdown if an overload occurs
teamreprap
Hindsight says I should have picked a power supply with 20+ amps to power my reprap from the start, but since I'm using RAMPs - it's really easy to use a separate power supply for only the heated bed. For me, a 203W X-Box 360 Power Supply has proven to be a functional, cheap solution for powering the heated bed or the electronics (~17 amps is not enough for both).
Re: XBox 360 PSU confusion May 28, 2014 08:35AM |
Re: XBox 360 PSU confusion May 28, 2014 09:04AM |
Re: XBox 360 PSU confusion May 28, 2014 09:15AM |
Re: XBox 360 PSU confusion June 26, 2014 06:18PM |
Re: XBox 360 PSU confusion June 26, 2014 06:23PM |
Re: XBox 360 PSU confusion September 12, 2014 06:14PM |
Re: XBox 360 PSU confusion September 15, 2014 01:55PM |
Because most switching power supplies don't like to be ran in parallel with one another. If you can guarantee that they won't share a common supply or ground plane, that's fine. But weird things can happen if they do share a ground plane. By the time you deal with the hassle of isolating things as well as paying for two power supplies, you might have well bought a single power supply that's big enough. It's not like our power demands are that much or require super clean power.Quote
plexer
Xbox 360 power supplies are so cheap though why not just run 2? 1 for 11a heated bed and one for the 5a supply for the rest of the printer hell buy several then you can use them on other machines and stuff too
