Breaking Y axis a4988 when powering ramps August 06, 2015 01:07PM |
) simply powering on the atx. After removing the diode (obviously I had to use a new arduino), again just powering on the atx caused the y axis a4988 to die. And it happened twice!|
Re: Breaking Y axis a4988 when powering ramps August 06, 2015 03:54PM |
Never plug or unplug anything with power on. I learned this the hard way.Quote
Also, do you think that powering on the atx, and then connecting it the board could solve this problem?
Re: Breaking Y axis a4988 when powering ramps August 06, 2015 05:39PM |
Re: Breaking Y axis a4988 when powering ramps August 07, 2015 10:27AM |
Re: Breaking Y axis a4988 when powering ramps August 07, 2015 11:07PM |
Re: Breaking Y axis a4988 when powering ramps August 08, 2015 12:42AM |
Re: Breaking Y axis a4988 when powering ramps August 08, 2015 01:35AM |
gmckee
Turning on and off the power supply by use of wall or switch shouldn't matter. I would say at this point to try plugging in components one at a time, turning off the power before plugging the next component in. Take your time. It could be another driver, I had a bad driver that was shorting out the whole system and replacing it solved my issues. Sorry that you are having such a hard time though.
Just to be sure I ordered a new ramps and 5 drivers
Cefiar
I would make sure you've got the polarity for the 5A input the right way around, and make sure you've got the stepper drivers plugged in correctly and not off-by-one hole.
