A clone Arduino Mega lost USB connection.
August 08, 2016 09:36AM
I'm running Devuan Linux.
In middle of printing, the USB connection got lost suddenly. Bulbul Junior stalled.
Pronterface was complaining serial port errors.
The USB adapter was gone:
Bus 001 Device 042: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
$ lsusb
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 005: ID 050d:706a Belkin Components 2-N-1 7-Port Hub (Upper half)
Bus 001 Device 002: ID 050d:0706 Belkin Components 2-N-1 7-Port Hub (Lower half)
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 003: ID 056a:0017 Wacom Co., Ltd CTE-450 [Bamboo Fun]
Bus 004 Device 002: ID 04b4:0101 Cypress Semiconductor Corp. Keyboard/Hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
I removed the RAPMS 1.4 shield from the board and plugged in USB cable. It wouldn't response.
Hmm... I plugged in Arduino Uno with the same USB cable. Uno was working fine.
The clone Arduino Mega came with a RAMPS 1.4 kit I bought one and half years ago.
This board had been running for printing 5 kg of PLA. I wouldn't expect it lasts few years anyway.
If I replace the USB driver chip on it, would it be usable again?
I might give a try for learning experience.
Re: A clone Arduino Mega lost USB connection.
August 08, 2016 06:14PM
I'd suggest that it's probably cheaper and quicker to just replace the board. And buy another as a spare.
Maybe replacing the USB driver will fix it. But it could equally be the connector or the CPU or something else. Is there a power LED on the Mega board? Is there 5V on the board?
August 09, 2016 07:32AM
@frankvdh
Robotdigg homepage suggests replacement of 1117 voltage regulator or USB driver chip could salvage a dead Arduino Mega.
[www.robotdigg.com]
Note: It's a shame that Mega 2560 R3 is Not that durable as Ramps 1.4 Board.
1. Unstable power supply, shortage on stepper driver or limit switch will cause problem to Mega 2560 R3
2. Can not burn latest firmware to it.
If the CPU is burnt, please drop the controller. 1117 power regulator or usb chip 16u2 problem, you may change the module to fix it. - See more at: [www.robotdigg.com]
When I plugged USB cable on it, the green LED light turned on.
I'll bring the dead board to a electronic shop tomorrow, check the voltage regulator first.
