Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 24, 2017 03:08AM |
Dust
Some mounting holes might be nice.... cant see any
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 24, 2017 08:56AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 24, 2017 09:26AM |
xebbmw
@lkcl: why not use A5984 stepper driver for the dual stepper board? It can be configured up to 32 micro steps and it less noisier than A4982. In my opinion it is a better choice but depends on the actual cost for the chip (although at Digikey A5984 is less expensive than A4982).
always a mistake: i wanted to at least get something ready which wasn't as costly as the TMC2660 board, but couldn't bring myself to use the A4988.
a whole extra $0.25, i can hardly bear the suspense at the increased cost.|
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 24, 2017 10:37PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 25, 2017 03:19AM |
xebbmw
Can you point me to an eagle library for A4982? In the allegro library i did not find one for tssop24 package...
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 25, 2017 09:29AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 25, 2017 10:46AM |
xebbmw
Thanks, I just realized I am already using that library. I am designing a 5 steppers board using Polulu drivers for Arduino Due,
but I did not checked before that library.
Some ideas that I use and you might include then in your RAMPS 1.4.2:
I added to my board is a DC-DC switching converter for 5V (the purpose is to supply power to a graphic display).
In the same time Polulu drivers can be driven by a power supply of 3.3 or 5V using a jumper. Also I have a DC-DC switching converter for 12V on the board so I could supply the board with 24V (for example for stepper motors). The fans are powered from 12V.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 25, 2017 05:19PM |
Sorry, my mistake hereQuote
lkcl
RD3D not RAMPS 1.4.2
I agree with you here, but my understanding is that a graphic controller would absorb a lot of current comparing with how much the Arduino Due might deliverQuote
lkcl
Most of the LCD controllers i've seen - actually most arduino-style shields - use 3.3v ICs that are 5V tolerant.
My design is based on DUE3DOM board from here. As I said is not finished yet. I have included 5 steppers, one heat bed output, two hot end outputs and three fans. My printer is a delta kossel that is driven by a RAMPS with ATMEGA2550. I have one spare board Arduino DUE that I want to use it with the new shield.Quote
lkcl
it would be great to see clearly the design you've come up with, if you can publish the eagle files i can take a look, you wouldn't need to explain it in words (which are often hard to get right and take a lot of time)
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 26, 2017 02:30AM |
xebbmw
lkcl
lkcl
My design is based on DUE3DOM board from here. As I said is not finished yet.Quote
lkcl
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 26, 2017 05:26AM |
lkcl
not publishing what you're doing also makes your life incredibly difficult.
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 26, 2017 05:59AM |
Traumflug
lkcl
Yes and No. With Gen7 I initially published work in progress, too. The result was, people etched and soldered PCBs from this half-finished work and found it not working (as expected). Asking to read instructions is asking too much from average users :-)
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 26, 2017 06:43AM |
lkcl
how exactly did you publish them?
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 26, 2017 07:22AM |
Traumflug
lkcl
'git push' of the design files, no Gerbers.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 26, 2017 08:21AM |
lkcl
... and people still went ahead with sending them to factories, without any kind of announcement or communication along the lines of "i'm going to send these to a factory, is that a good idea yes or no?"?
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 26, 2017 08:37AM |
great!Quote
Traumflug
lkcl
First of all, the point of a Gen7 is that one needs no factory. Interested people can download the design and make PCB and controller on their kitchen table.
Regarding communications: all you'll see is a "This design doesn't work!" in the forum.
After the fact, of course. And then everybody knows: "Stay away, this design doesn't work!".
People will find this by googling and find it after a working release was published, too, of course. One negative comment outweights 5 or 10 positive comments, so your design is down the toilet before its first release already.
The only way to deal with this is to publish finished work, only. Works.
If you want to discuss aspects, publish informative, but unusable sections, only. Like partial schematics as PNGs. And also only inside discussions, so people immediately see what's going on.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 26, 2017 01:01PM |
xebbmw
lkcl
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 26, 2017 05:07PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 26, 2017 05:47PM |
dc42
Does the Arduino Due provide sufficient 5V current without overheating the voltage regulator if you feed 24V to the power input pin (if it can accept 24V) and you are powering a 12864 LCD from +5V? I very much doubt it. One of the well-known flaws of Arduino/RAMPS is that if you use a 12864 LCD, the voltage regulator on the Arduino mega is likely to overheat even at 12V input.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 26, 2017 06:06PM |
lkcl
what you're referring to, dc42, as i understand it, is that some of these LDO regulators work like a car brake, in effect diverting the extra voltage directly into heat. so if you supply them with 8V and demand 1A current it's fine... but if you put in 12v and demand 1A current, the LDO regulator throws off all of that extra power (12-5 volts times 1A = 7 watts!!) as heat. this is what the "thermal dissipation" figure is about in the datasheet.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 26, 2017 07:22PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 26, 2017 10:02PM |
for me electronics and 3d printers is just a hobby. this is my first experience with such a complex board. see my board in the attachment:Quote
lkcl
did you see me saying that, throughout the development process of RD3D? did i say, "i'm sorry, i'm not going to publish this work because it's quotes not finished quotes?"
now nobody can understand fully what you are saying, they can't help you if it's not easy to follow what you're doing. they can't see it, they can't contribute. you are the sole exclusive person who can work on it.
not publishing what you're doing also makes your life incredibly difficult. you have to explain - fully - in words - exactly what you're doing.
lkcl
xebbmw
in short, the due provides sufficient 3.3v current, the arduino provides sufficient 5.0v current, so you don't need a regulator, you just select whichever's needed (that's if you want a dual arduino/due-capable board).
if you want a due-only board you can just route 3.3v through to expansion headers, as there's more than enough current and most "shields" - i prefer the word peripherals - are 3.3v ICs that are 5v tolerant. there's a few exceptions but i've not yet encountered any peripherals that were actually needed for the (specialist) use of a 3D printer / CNC controller board.
dc42
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 27, 2017 02:43AM |
frankvdh
This kind of voltage regulation sounds appalling to me. For 65c you can buy a DC-DC buck converter that is claimed to be 97% efficient. Worst case, you could have a couple of pins on your board to accept 5V, perhaps placed the right distance apart for the buck converter to be soldered directly to them. Best case, build the buck converter circuit into the board itself.
Or am I missing something?
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 27, 2017 05:30AM |
xebbmw
as dc42 mentioned
dc42
the 5v regulator is needed to power a ReprapDiscount Full Graphic LCD. see other comments that i found about the issue here
as 5V DC-DC regulator i am looking to use RT7247B from Richtek. or should i use MP1484 (this is very cheap from Aliexpress). @dc42: any comments on these parts?
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 27, 2017 06:56AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 27, 2017 08:04AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 27, 2017 09:44AM |
dc42
Busk converters are tricky things to get right, so unless you have the right experience, I advise against designing on one-board.
I suggest you use a 7805 instead, which a user can add a heatsink to if necessary, or replace by one of the 7805-sized buck converters you can buy on eBay.
This wouldn't be a good solution for a board to go in a manufactured 3D printer, but for a board aimed at hobbyists it's entirely adequate IMO.
Loads on the 3.3V rail are normally light, so the 3.3V regulator on the Arduino Due should be adequate.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 27, 2017 01:53PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 27, 2017 04:19PM |
dc42
The load won't get anything like 1A in normal use. More like 200mA or possibly 250mA.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 30, 2017 03:59AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 30, 2017 06:46AM |
