Re: New RAMPS design June 17, 2018 08:27PM |
Re: New RAMPS design June 17, 2018 08:38PM |
Re: New RAMPS design June 17, 2018 08:41PM |
Re: New RAMPS design June 17, 2018 08:54PM |
Re: New RAMPS design June 17, 2018 11:12PM |
Re: New RAMPS design June 17, 2018 11:17PM |
Re: New RAMPS design June 18, 2018 08:26PM |
Re: New RAMPS design June 18, 2018 09:05PM |
Re: New RAMPS design June 19, 2018 05:24AM |
Re: New RAMPS design June 19, 2018 07:12AM |
Re: New RAMPS design June 19, 2018 08:32AM |
Re: New RAMPS design June 22, 2018 08:28AM |
aenertia
Is Due event a consideration (it's not even produced anymore)
Re: New RAMPS design June 24, 2018 02:05PM |
Re: New RAMPS design June 24, 2018 02:53PM |
Re: New RAMPS design June 24, 2018 03:43PM |
Re: New RAMPS design June 25, 2018 08:39AM |
Re: New RAMPS design June 25, 2018 09:12AM |
Re: New RAMPS design June 30, 2018 07:20AM |
boelle
about the fuses... i think these 2 types would be best, cheap and easy to get
[www.thansen.dk]
[www.thansen.dk]
Re: New RAMPS design June 30, 2018 08:01AM |
Re: New RAMPS design June 30, 2018 08:19AM |
Re: New RAMPS design June 30, 2018 09:35AM |
Re: New RAMPS design July 01, 2018 02:29AM |
Re: New RAMPS design July 01, 2018 03:33AM |
Ah, good to know.Quote
o_lampe
Fast fuses are sand filled with a glass-housing.
It is indeed. However, because of the amp load/level, there is a need for a certain (typically high) level of copper going to and from the fuse.Quote
o_lampe
Leading heat away from the fuse into the PCB is slowing down the fuse.
Ah yes, I remember this comment. Now I am beginning to see the merits of why to do thisQuote
o_lampe
I repeat my earlier proposal: use inline fuses and save the PCB space for other stuff.
Re: New RAMPS design July 01, 2018 03:53AM |
Re: New RAMPS design July 01, 2018 04:09AM |
So far these experiments has indeed lead me to conclude that fuses are useful for protecting wires (and pcb traces) against overheating.Quote
boelle
I guess the fuses are only good for shorts?
They do indeed take up more space.Quote
boelle
i know that for the cylinder shape glass fuses they come in a fast and slow acting type, but would they not take up more space?
Re: New RAMPS design July 02, 2018 03:40PM |
Re: New RAMPS design July 02, 2018 04:19PM |
cozmicray
?? Where does the arduino plug in ??
cozmicray
Why not MOSFET with large tab off the PCB, that can be thermally synced with radiator?
Would over rating the MOSFET protect it or just lead people to draw more on it?
cozmicray
What is fate of MrAlvin-RAMPS 1.7
Re: New RAMPS design July 02, 2018 04:22PM |
Re: New RAMPS design July 03, 2018 07:26AM |
Thank youQuote
cozmicray
Outstanding thread
Bravo on New RAMPS
Under neath this board, like previous RAMPS boards, and like any Arduino shield.Quote
cozmicray
For typical use, it is not necessary to do that. Otherwise it is a good idea, and a design option that is often being used.Quote
cozmicray
Perhaps. For typical use (a 20 x 20 cm heat bed) this board should easily be able to handle it. For some of the larger (and newer) heat-bed sizes, it should still be able to keep up with most of them. My goal has been to be able to handle a 20A heat-bed, with some headroom. So if a heat-bed draws 23A it should still be abler to work just fine. At that point the screw terminal will however become the bottle neck.Quote
cozmicray
Yes, that would be the recommended path to choose.Quote
cozmicray
If you need high current control --- do it off the main board with control from main board?
Well, no fate has been decided yet So far it is all in the prototype (and testing) stage.Quote
cozmicray
What is fate of MrAlvin-RAMPS 1.7 --- MrAlvin / Kimchi electronics production?
Re: New RAMPS design July 03, 2018 11:47AM |
