Ramps 1.4 + ATX Power Supply
November 26, 2019 12:28PM
Hi folks
I have a Tacens 12V 26A power supply
PSU can start itself, but when i pluged it to Ramps 1.4, NOTHING.
What can be the reason?
Thanks to all in advance!
Edited 1 time(s). Last edit at 11/28/2019 07:39AM by Versvs.
Re: Ramps 1.4 + ATX Power Supply
November 26, 2019 12:40PM
My wiring is just ;
Green to GND (for self start)
2 x 12V (yellow) ATX to Ramps
2 x GND (black) ATX to Ramps
Ramps + Arduino Mega
Arduino pluged to laptop via USB
I got nothing hooked up on ramps (heatbed, driver, ext.)
November 26, 2019 06:11PM
Pictures of ramps power plugs and wires to check wiring?
November 27, 2019 08:48AM
Here you can see the attachment for wiring
I also loaded the 3.3V sense pin (brown) with any 3.3V (orange) cable
PS.: Arduino + Ramps combination without PSU
Arduino = Plugged to laptop = Ramps Led1 blinks once
Clicking Ramps Reset button = Led1 blinks twice
open | download - psu con.jpg (221.5 KB)
November 27, 2019 09:55AM
Mainly wanted to check you had the + and - correct, and you do.
Some power supplies need a load on the 5v lines...
November 27, 2019 10:11AM
When i connect a red 5V cable with a GND cable PSU ıs not starting
November 27, 2019 10:56AM
That is not a load, that is a short!
And shorts always stop the power supply, and if they aren't protected they explode!
Never ever connect a supply line to GND.
You need a load. Something with resistance.
November 27, 2019 11:02AM
I connected 5V with 10 ohm resistor. (then realized that is not necessary 3.3V sense short is enough)
I pluged only 12V 11A section. This case PSU is starting and giving 12V to board.
Just 12V5A section is not working. But Ramps seems very clean from outside.
November 27, 2019 11:29AM
Long story short;
Only 12V 11A section connected = PSU starting and giving 12V to Ramps
When 12V 5A section is connected = PSU is not starting
As seen in photos there is no visible problem.
How can i test for the malfunction reason?
Edited 1 time(s). Last edit at 11/28/2019 07:54AM by Versvs.
open | download - front.jpg (496.2 KB)
open | download - back.jpg (497 KB)
November 28, 2019 09:33AM
continuity test:
5A section : beeping
11A section : not beeping
open | download - 5a section.jpg (495.4 KB)
open | download - 11a section.jpg (417.2 KB)
November 28, 2019 09:58AM
5A section is definitely faulty.
Check D2 (the one behind the big yellow square poly-fuses) This is designed to blow if you plug the power supply in backwards, but sometimes it stays shorted.
You can just remove it, but then make sure you don't get the + and - wires swapped!
November 29, 2019 04:12AM
Thank you so much
Now it is working
But i will reinstall d2 with a new one for sure
