First Print! Minor Issues
Posted by Docmani
June 20, 2013 04:19PM
So here is my first print on my brand new Prusa Mendel!
Actually, my first prints had each layer offset at random distances (I lowered the default_acceleration as suggested on the wiki, and the problem went away).
So this was at 0.4mm layer height with a 0.5mm nozzle. Not bad, but the top block appears to have had issues. I pretty much used all the default settings in Slic3r.
This was a calibration object I downloaded from Thingiverse. Each step is 5mm high and 5mm wide.
Is the top layer messed up due to limitations of my nozzle or is there something I can do to improve it?
Any help is appreciated. Thanks!
open | download - photo.JPG (65.3 KB)
Re: First Print! Minor Issues
June 20, 2013 04:54PM
Use a fan or print 2, 3 or 4 objects at the same time.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
June 20, 2013 05:50PM
If PLA, use a fan, if ABS, print 2 at the same time a bit away from eachother to allow cooling.
