Print leans in both directions February 04, 2014 09:35PM |
Re: Print leans in both directions February 10, 2014 09:36AM |
Re: Print leans in both directions February 10, 2014 09:45AM |
Re: Print leans in both directions February 12, 2014 10:36AM |
Elk
Hi there…
I have similar issues sometimes… I was thinking about temperature changing the lenght of the belt / axis as they slowly heat up… perhaps you might want to try to preheat the machine for a longer time than necessary (for example 15mins longer than necessary to reach heatbed max-temp to make sure belt and axis-rods are all at max. possible temperature…
Not sure if it really helps but I was handling it that way and had better results…
Regards
Sebastian
Jc61990
if you type M503 into the console on repetier what is the Value of M205, Specifically the X value. that is the Jerk, you could have it set too high. Thats one possibility that comes to my mind
Re: Print leans in both directions February 12, 2014 12:52PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Print leans in both directions February 12, 2014 01:16PM |
Re: Print leans in both directions February 12, 2014 03:23PM |
mza1979m
Jc61990
Ok, I'm not entirely certain what I'm supposed to do here... I typed M503 into G-Code field under the "Manual Control" tab, but absolutely nothing happens, and nothing new shows up in the log at the bottom of the window.
Re: Print leans in both directions February 12, 2014 04:14PM |
Re: Print leans in both directions February 12, 2014 08:07PM |
Re: Print leans in both directions February 13, 2014 11:39AM |
Re: Print leans in both directions February 13, 2014 11:55AM |
>>>M501 SENDING:M501 echo: Stored settings retrieved echo: Steps per unit: echo: M92 X79.00 Y79.00 Z2560.00 E755.00 echo: Maximum feedrates (mm/s): echo: M203 X250.00 Y250.00 Z5.00 E25.00 echo: Maximum Acceleration (mm/s2): echo: M201 X7000 Y7000 Z500 E10000 echo: Acceleration: S=acceleration, T=retract acceleration echo: M204 S5000.00 T5000.00 echo: Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X25.00 Z0.40 E5.00 echo: Home offset (mm): echo: M206 X0.00 Y0.00 Z0.00 echo: PID settings: echo: M301 P22.20 I1.08 D114.00 >>>M503 SENDING:M503 echo: Steps per unit: echo: M92 X79.00 Y79.00 Z2560.00 E755.00 echo: Maximum feedrates (mm/s): echo: M203 X250.00 Y250.00 Z5.00 E25.00 echo: Maximum Acceleration (mm/s2): echo: M201 X7000 Y7000 Z500 E10000 echo: Acceleration: S=acceleration, T=retract acceleration echo: M204 S5000.00 T5000.00 echo: Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X25.00 Z0.40 E5.00 echo: Home offset (mm): echo: M206 X0.00 Y0.00 Z0.00 echo: PID settings: echo: M301 P22.20 I1.08 D114.00
Re: Print leans in both directions February 13, 2014 09:08PM |
Re: Print leans in both directions February 13, 2014 09:30PM |
