MK3 heatbed cannot reach target temp
April 22, 2014 07:05AM
I have just purchased a MR3 heatbed (3,5 mm Aluminium one !! ), I run Ramps 1,4 on Arduino MEGA. It can reach about 63 deg C and not more. I have put foam insulation under the heatbed, i have connected the cables to 1+ and 2-. (If i connect + to 1, and - to 2&3 the board will disconnect after a few seconds.) Cables should be thick enough and they are not getting hot. Have capton tape on the alumium surface. a) I have tried hairspray = warping. b)I have tried to clean surface with acetone = warping, c)have tried abs/acetone solution = warping. All with 63deg C heatbed and ABS set to 220 deg C.
Does anyone have an idea why the heatbed cannot reach target of let us say 100deg C ? i have a feeling that that might solve the warping issue if the bed temp goes up.
Wang Fei
Re: MK3 heatbed cannot reach target temp
April 22, 2014 04:32PM
Sounds like you are putting power (at 12V?) onto half of a dual power heatbed, (and you get a disconnect by putting insufficient power into both halves) See [reprap.org]
April 22, 2014 09:18PM
Hi DaveX,
I connect according to this [reprap.org] (Even my one is a Mk3 the schematic on it is the same as this).
I am using a hacked PC powersupply of 420 Watt. Inside the powersupply was a total of 6 cables for 12 volt from the pcb. I have connected 3 together with a much thicker cable, which again is connected to terminal. Other 3 connected in same way to other terminal.
Do you mean that the powersupply is too small ?
April 23, 2014 03:42AM
According to the link you posted, Pin 1 is ground, pins 2 and 3 are positive.. Dunno if that will make a difference?
_______________________________________
Waitaki 3D Printer
April 23, 2014 02:17PM
wangfei
Hi DaveX,
I think the power supply is too small -- If you try to pull too many amps, I think it shuts down and resets to give you the disconnection. If you can hook the power supply's 12V up directly to the heatbed, bypassing your electronics, can it deliver a full ~10A and heat the bed? If you are just hooking up to 1&2, you are only powering half the bed, and probably only drawing ~5A.
The polarity should make no difference, because you are using the traces on the heatbed as a resistor, and they do not care which way the power goes.
April 23, 2014 07:38PM
The usual words come to mind: multimeter to measure bed resistance, look for a short caused by a mounting screw, etc.
Per the link above, "resistance between 1.4 and 1.6 ohm for the 12V" .....
Edited 1 time(s). Last edit at 04/23/2014 07:41PM by vreihen.
Re: MK3 heatbed cannot reach target temp_SOLVED
April 28, 2014 08:45AM
Hi everyone,
Many tks for the different advices.
DaveX pointed out that the powersupply was to small. YES. I did connect a spare other PC powersupply directly to the heat bed and with connection to 1,2 and 3. Result was a stable temp. increase to 95 degC at first test which was enough to confirm your idea.
And to vreihen : i did measure a resistance of about 1,6 ohm so this should be ok.
So after making above to simple tests i did buy a new PC power supply and hacked it the way i had done before (seen on Youtube). I did buy a 500W. (see image of label here on attached file).
Result is that my Mk3 heat bed now can reach about 105 deg C in about 18-20 min. It does not seem to be going higher, but print tests has proven to be almost warp free. So i consider this issue to be solved for now. (I am currently printing 100x 20 mm parts which seem to be 100% warp free)
So once again thanks for all the advice and i hope this will help others with same or similar issues.
open | download - Powersupply_500W.jpg (59 KB)
September 14, 2014 01:58PM
wangfei
Result is that my Mk3 heat bed now can reach about 105 deg C in about 18-20 min. It does not seem to be going higher....
Is this time common/normal ??
September 15, 2014 08:26AM
Nope. I get to 110c in about 10-15 minutes
