can anyone explain the cause of this?? May 11, 2014 11:18AM |
Re: can anyone explain the cause of this?? May 11, 2014 12:18PM |
Re: can anyone explain the cause of this?? May 11, 2014 04:16PM |
Re: can anyone explain the cause of this?? May 11, 2014 04:25PM |
Re: can anyone explain the cause of this?? May 11, 2014 06:21PM |
Re: can anyone explain the cause of this?? May 12, 2014 05:26AM |
Re: can anyone explain the cause of this?? May 14, 2014 04:48PM |
konwiddak
Do you run a pipe from filament reel to extruder? If you don't then then loose filament can pull on the X carriage lifting it upwards. This causes every n layers to be too thick to lay properly.
Try unwinding enough of a coil of filament before printing and see if the issue goes away.
Also could be temperature swinging due to incorrect pid settings. At 70mm/s your extruder may only just maintain 230C. Monitor temperature over a print and see if it stays constant.
Try printing at say 30mm/s does the issue go away? Could be extruder gears binding every n rotations.
Re: can anyone explain the cause of this?? May 14, 2014 04:50PM |
Re: can anyone explain the cause of this?? May 20, 2014 03:33PM |
Re: can anyone explain the cause of this?? May 20, 2014 07:23PM |
