Hi colleagues!
I have one
RepRapPro Tricolour Mendel.
And problem is that setting offsets via M206 or G10 command doesn't work. I moved extruder to corner of bead, which one must be zero, then get it pos, then set up offsets with this values, according
instruction, e.g.
»>M206 X-57 Y-3
SENDING:M206 X-57 Y-3
»>G10 X-57 Y-3
SENDING:G10 X-57 Y-3
But there is no "OK" confirmation from printer and GET POS command return same values.
Your assistance will be much appreciated.
P.S. Attach below output of M503 command if it matters.
SENDING:M503
echo: Steps per unit:
echo: M92 X87.49 Y87.49 Z4000.00 E660.00
echo: Maximum feedrates (mm/s):
echo: M203 X300.00 Y300.00 Z3.00 E45.00
echo: Maximum Acceleration (mm/s2):
echo: M201 X800 Y800 Z30 E250
echo: Acceleration: S=acceleration, T=retract acceleration
echo: M204 S1000.00 T1000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s), Z=maximum Z jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X15.00 Z0.40 E15.00
echo: M206 X-57.00 Y-3.00 Z0.00
echo: PID settings:
echo: M301 H1 P12.00 I2.20 D80.00 W125.00
Slave not working! Default values are:
M301 H2 P12.00 I2.20 D80.00 W125.00
M301 H3 P12.00 I2.20 D80.00 W125.00
FPU Enabled no
Axis 0 max: 210.00 Axis 1 max: 210.00 Axis 2 max: 140.00
Bed/extruder 0 beta: 4126.00 resistor: 4700.00 thermistor: 9999.99 inf: 0.01
Bed/extruder 1 beta: 4138.00 resistor: 4700.00 thermistor: 99999.91 inf: 0.09
Bed/extruder 2 beta: -273.00 resistor: -273.00 thermistor: -109.27 inf: -273.00
Bed/extruder 3 beta: -273.00 resistor: -273.00 thermistor: -109.27 inf: -273.00
Extruder: 0 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 0.00 operating temp: 0.00
Extruder: 1 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 0.00 operating temp: 0.00
Extruder: 2 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 0.00 operating temp: 0.00
