Need help with improving print quality December 16, 2014 12:33AM |
Re: Need help with improving print quality December 16, 2014 03:48PM |
abyss996
can see in the attachments, I have improved the quality to an extent. But I'm stuck at this point.
Below are the settings in Cura 14.09:
Advanced:
Nozzle Size: 0.5mm
Retraction speed: 120mm/s
Distance: 4.5mm
Travel speed: 1500mm/s
I'm ABS for my prints and Repetier v1.0.6 for printing
The prints(I was unable to attach the files with this post.):[1drv.ms]
Thanks in advance
Re: Need help with improving print quality December 17, 2014 05:48AM |
Re: Need help with improving print quality December 17, 2014 07:29AM |
That's not everytime true. With a DD-Bowden my retract speed is 120mm/s with 4.5mm, when I use a 0.25mm-nozzle at my E3D-V6. If you have a Wade, then 120mm/s is too much.Quote
RDEng
what are you doing )))
retraction speed is to high. set it 30mm/s also distance too.
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Need help with improving print quality December 17, 2014 09:10AM |
Wurstnase
RDEng
Also you push too much material. Reduce your flow. You could use the Triffid Calibration Guide for this.
Re: Need help with improving print quality December 20, 2014 04:03AM |
