Cura export splitting object!
March 08, 2015 06:04AM
Attached is the .stl file for my double bulldog lite extruder mount.
Meshmixer, 123d Design and cura show the object as one joint object but when I try to print, the parts of the extruder mount get split!
Is my computer lying to me or is the printer confused?
(Sorry no pics as lost my usb leads angry smiley )
open | download - doublehead03.stl (570.8 KB)
Re: Cura export splitting object!
March 08, 2015 08:58AM
It looks as though you took two parts and just mashed them together with some overlap. That doesn't work. In your CAD file once you've positioned the parts you have to combine them to a single solid before you export as an STL file. There is usually some sort of "combine" or "join" function on a solids menu that is used to do that, but it varies depending upon the CAD package you are using.
The overlap is in the light gray area in the middle where you can see the mesh lines crossing:
March 08, 2015 10:32AM
That explains it, Autodesk software is shite!
I used mesh mixer to combine them into one object but it looks like the software doesn't work.
Thank you for looking.
March 08, 2015 10:54AM
I think meshmixer should be able to do it, but I haven't used it much, so I can't tell you what to do with it to correct the problem.
March 08, 2015 01:24PM
That file is the results of meshmixer.
Obviously not good enough for what it's intended angry smiley
March 08, 2015 07:25PM
To be honest, I doubt your knowledge of meshmixer then. Meshmixer is a very powerful program and can fix most errors an STL can have.
Are you sure you're not overlooking an option in meshmixer?
http://www.marinusdebeer.nl/
March 09, 2015 01:46PM
Ohmarinus
Which the fix option or the Combine option?
The one highlighted when you select all parts?
The picture shows the previous file state and the attached files is the output AFTER clicking combine, saving as mix then outputting to stl!
Mind you getting mesh mixer to not crash is difficult!
Edited 1 time(s). Last edit at 03/09/2015 01:49PM by GRAYWOLF.
open | download - Screen Shot 2015-03-09 at 17.29.16.png (257.4 KB)
