The BASICS for 1st Time - HELP June 07, 2015 10:23AM |
Re: The BASICS for 1st Time - HELP June 07, 2015 06:40PM |
Re: The BASICS for 1st Time - HELP June 07, 2015 07:03PM |
Re: The BASICS for 1st Time - HELP June 07, 2015 09:51PM |
Re: The BASICS for 1st Time - HELP June 08, 2015 02:55PM |
Re: The BASICS for 1st Time - HELP June 10, 2015 11:50PM |
Re: The BASICS for 1st Time - HELP June 11, 2015 03:18PM |
Re: The BASICS for 1st Time - HELP June 11, 2015 03:20PM |
Re: The BASICS for 1st Time - HELP June 11, 2015 03:32PM |
Re: The BASICS for 1st Time - HELP June 11, 2015 03:43PM |
Re: The BASICS for 1st Time - HELP June 11, 2015 05:12PM |
Re: The BASICS for 1st Time - HELP June 13, 2015 12:34PM |
Re: The BASICS for 1st Time - HELP June 14, 2015 05:02AM |
Re: The BASICS for 1st Time - HELP June 14, 2015 09:34AM |
Re: The BASICS for 1st Time - HELP June 15, 2015 02:31AM |
Re: The BASICS for 1st Time - HELP June 15, 2015 08:25AM |
Re: The BASICS for 1st Time - HELP June 20, 2015 10:36AM |
waitaki
This is what I suggest....
Remove the filament from the extruder completely so you are left with a nice clean non-oozing nozzle.
Level the bed all round. (you should not need to keep doing this unless you have build problems - mine was set 2 or 3 years ago and is still in spec).
Heat the bed to 60C
Switch on the hotend - 150C should be enough for setting up.
Adjust the nozzle gap using the pronterface home command to somewhere between 0.05 and 0.1mm (a till receipt is typically .05 and a sheet of 80gsm photocopy paper is 0.1mm). A piece of copy paper should drag lightly under the nozzle when Z is homed.
Once that's all good, install the filament, set hotend to temp and ensure you have primed the hot-end before printing.
Try again and see what you get. If the set-up is spot on, it makes it easier to diagnose problems after.
and finally...
Have a stiff drink!
Re: The BASICS for 1st Time - HELP June 20, 2015 05:12PM |
