Limit model cooling fan air to only the model
June 19, 2015 11:46PM
my machine only recently got good enough that I can concentrate on the finer issues. One thing that influences quality quite a bit is irregular layer stacking. I'm ignoring the influence of filament diameter inconsistencies here and only focus on how heat make some layers expand more or less. Im also ignoring the influence the heat bed has on that effect if its set to bang bang mode.
That leaves the hotend cooling fan. I recently added the torus shaped 360° fan funnel with a squirrel cage fan and that makes cooling much better, but still I have a temp difference of ca +- 1-2°C when the fan goes from 0 to 100% and there is no way in slicer to smooth out how the fan activates afaik.
So I wanted to open a discussion how this issue is handled by you.
Cheers
Re: Limit model cooling fan air to only the model
June 20, 2015 06:08AM
I have only a normal funnel with the tip extented with aluminium tape. Add a potentiometer to control your fan speed manually. Cura slicer has fan settings: Fan full at height etc.
Prusa i3, Ramps 1.4. Catnozzle 0.4mm
SketchUp - Enveloping Globoid Worm Gear - Part One - 3D Printed: [youtu.be]
DesignSpark Mechanical & more precise screw thread: [youtu.be]
Nicer Screw Thread In SketchUp ( Bolts,Nuts): [youtu.be]
How To Model A Heart Shape In SketchUp: [youtu.be]
How To Draw 3D Printable Snap Fit Ball Joint In SketchUp: [youtu.be]
June 20, 2015 02:01PM
You have a potentiometer on the model cooling fan?
June 21, 2015 05:01AM
No. I have only an on/off switch. I could put a potentiometer if I want to make a smooth start, but I don't have problems with my fan. It's not very powerfull. I switch it on usually after the raft layer if needed. [fearless-assassins.com]
