My First print with problem =( April 20, 2016 09:57AM |
/** * MOVEMENT SETTINGS */ #define HOMING_FEEDRATE {1500, 1500, 150, 0} // set the homing speeds (mm/min) // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT { 80.5642698905136, 80.5642698905136, 3969.1600944271922, 100.558274724933 } // XYZE Default steps per unit for Ultimaker #define DEFAULT_MAX_FEEDRATE { 300, 300, 2, 25 } // XYZE (mm/sec) #define DEFAULT_MAX_ACCELERATION { 400, 400, 100, 10000 } // XYZE Maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 100 // XYZE acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 1000 // E acceleration in mm/s^2 for retracts #define DEFAULT_TRAVEL_ACCELERATION 400 // XYZ acceleration in mm/s^2 for travel (non printing) moves // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) #define DEFAULT_XYJERK 5.0 // (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec)
Re: My First print with problem =( April 20, 2016 12:18PM |
Re: My First print with problem =( April 20, 2016 01:06PM |
Re: My First print with problem =( April 20, 2016 05:36PM |
Re: My First print with problem =( April 20, 2016 06:23PM |
MrBaz
Bed isn't level (can tell by the first level).
Extruder pulses could be causing the moire.
Re: My First print with problem =( April 20, 2016 11:07PM |
engmaster
MrBaz
My bed still close from extruder, tested with office paper. I need nozzle touching the bed or one office paper? With office paper distance, when print start the nozzle still in 0,3mm away showed in M114(first layer size).. So I have the officepaper size + 0,3mm... It is correct or need change?
The first layer have 0.3mm and my nozzle is 0.4mm (filament PLA 3,00mm)
humm.. The problem 2(corners) is caused by moviment(pulse) in extruder? I will revise it!
So, How I will resolve the the bootom and solid layers? All solid layers have this problem.
Re: My First print with problem =( April 21, 2016 02:50AM |
Re: My First print with problem =( April 24, 2016 07:17PM |
Re: My First print with problem =( April 25, 2016 08:10AM |
Re: My First print with problem =( April 25, 2016 11:10AM |
MCcarman
In slicer set the Z offset to NEGATIVE paper thickness. You have it at 0. This should get the first layer height correct. I.E. Paper is 0.1mm the Z offset should be -0.1
infill_overlap = 15% Seems a bit high for me. I would start with 0 and then increase it slightly if I had an issue.
Re: My First print with problem =( April 26, 2016 07:42AM |
Re: My First print with problem =( April 27, 2016 08:03PM |
