Diagonal lines around print May 12, 2016 12:39AM |
Re: Diagonal lines around print May 12, 2016 04:18AM |
Re: Diagonal lines around print May 12, 2016 05:11AM |
Re: Diagonal lines around print May 12, 2016 05:25AM |
Admin Registered: 16 years ago Posts: 13,902 |
Re: Diagonal lines around print May 12, 2016 05:31AM |
VDX
... this sort of paterns could be caused by regular speed variaton/fluctuation of the extruder-motor or by a not concentric hobbed bolt ...
Re: Diagonal lines around print May 12, 2016 05:39AM |
Re: Diagonal lines around print May 12, 2016 05:43AM |
Re: Diagonal lines around print May 12, 2016 06:19AM |
Re: Diagonal lines around print May 12, 2016 06:31AM |
Re: Diagonal lines around print May 12, 2016 07:04AM |
Re: Diagonal lines around print May 12, 2016 07:25AM |
but it doesn't show on the bottom of the orange cube. Might be that if the same pattern is now visible on the lower part of a new print of that same object and it was a temp. test like the blue cube next to it I would say that something broke or displaced at the lower print temperature.Quote
VDX
Re: Diagonal lines around print May 12, 2016 07:45AM |
Re: Diagonal lines around print May 12, 2016 09:42AM |
Re: Diagonal lines around print May 12, 2016 10:14AM |
Re: Diagonal lines around print May 12, 2016 11:00AM |
Re: Diagonal lines around print May 12, 2016 10:51PM |
Re: Diagonal lines around print May 13, 2016 07:22AM |
Re: Diagonal lines around print May 13, 2016 09:09AM |
Re: Diagonal lines around print May 13, 2016 01:47PM |
Re: Diagonal lines around print May 13, 2016 08:48PM |
JamesK
Oh well, another fine theory out the window.
Re: Diagonal lines around print May 14, 2016 09:03AM |
Re: Diagonal lines around print May 14, 2016 11:07AM |
Re: Diagonal lines around print May 15, 2016 03:16AM |
Re: Diagonal lines around print May 15, 2016 06:20AM |
Re: Diagonal lines around print September 13, 2016 07:00AM |
Re: Diagonal lines around print September 13, 2016 08:25AM |
geoffs
Dalek failed, my fault, so tried printing something else (this boat).
After printing the first couple of layers and then the fill, temperature was fluctuating and I started getting 'cold extrude prevented'
Not sure if the problem is related. Power supply is 12V30A so should be able to keep the hotend, hot. I did a couple of PID autotunes earlier today so pretty sure that's OK
Perhaps my crappy Geeetech RAMPS board is to blame? I'll try swapping it out - tomorrow.
Re: Diagonal lines around print September 21, 2016 08:57PM |
Re: Diagonal lines around print September 21, 2016 11:49PM |
Re: Diagonal lines around print April 06, 2017 01:22PM |
