priinter base supply region got fried...![]() February 12, 2017 11:55AM |
Re: priinter base supply region got fried...![]() February 17, 2017 11:37AM |
Re: priinter base supply region got fried...![]() February 17, 2017 01:16PM |
Re: priinter base supply region got fried...![]() February 17, 2017 03:16PM |
Re: priinter base supply region got fried...![]() February 17, 2017 05:51PM |
Re: priinter base supply region got fried...![]() February 17, 2017 10:15PM |
Re: priinter base supply region got fried...![]() February 18, 2017 02:40AM |
Re: priinter base supply region got fried...![]() February 18, 2017 03:38AM |
Re: priinter base supply region got fried...![]() February 18, 2017 09:45AM |
Re: priinter base supply region got fried...![]() February 18, 2017 10:11AM |
Re: priinter base supply region got fried...![]() February 18, 2017 07:36PM |
Re: priinter base supply region got fried...![]() February 18, 2017 07:39PM |
Re: priinter base supply region got fried...![]() February 18, 2017 11:15PM |
Re: priinter base supply region got fried...![]() February 19, 2017 12:23AM |
Re: priinter base supply region got fried...![]() February 19, 2017 12:35AM |
Re: priinter base supply region got fried...![]() February 19, 2017 02:51AM |
Re: priinter base supply region got fried...![]() February 19, 2017 03:03AM |
Re: priinter base supply region got fried...![]() February 19, 2017 09:55AM |
sigxcpu
My MKS Base 1.4 had weak solder point on both green sockets (power & bed). When playing with the screws, they move a little and the socket terminals get loose in the PCB. Found that using a thermo camera wondering why the sockets and the first 4-5cm of wires had 55 degrees C compared to 30 degrees for the rest of the wire.
So get cheap soldering iron, new sockets (they are called screw terminal blocks or something like this) and make sure you create strong electrical and mechanical connections. Also check if they are 5 or 5.08mm pitch, I don't know.
Re: priinter base supply region got fried...![]() February 19, 2017 10:01AM |
o_lampe
According to the BOM list of RAMPS 1.3 the green connector is called:
MSTBA 2,5 and MSTBT 2,5 (5.04mm spacing 4 connector)
It's not the same as yours and MKS is closed source, but if you look for Phoenix Contact resellers and find the right connector spacing you are on the right path.
If you are able do unsolder the burnt connector, you can solder the wire directly to the board and use any decent RC-Hobby plug you like. ( Deans T-connector or hobbykings XT60 )
Re: priinter base supply region got fried...![]() February 19, 2017 10:41AM |
Re: priinter base supply region got fried...![]() February 19, 2017 03:47PM |
Re: priinter base supply region got fried...![]() February 19, 2017 07:22PM |
Re: priinter base supply region got fried...![]() February 21, 2017 09:41PM |
Re: priinter base supply region got fried...![]() February 22, 2017 03:29AM |
Re: priinter base supply region got fried...![]() February 22, 2017 01:55PM |
gee. u is very nice! i dont trust myself cuz i almost fcked up my motherboard when i wired it, im new to this stuff and i should be careful...Quote
o_lampe
Why don't you grow some b@ lls and trust your own conclusion? The necessary information is there...
Re: priinter base supply region got fried...![]() March 01, 2017 04:48AM |
Re: priinter base supply region got fried...![]() March 03, 2017 10:51AM |
