Issues with printing larger objects March 24, 2017 11:03PM |
Re: Issues with printing larger objects March 25, 2017 01:19AM |
Re: Issues with printing larger objects March 25, 2017 03:18AM |
Re: Issues with printing larger objects March 25, 2017 03:42AM |
I've carefully watched my printer, and it doesn't seem to hit anything or make any sounds to indicate jamming, impact or contact with obstruction. It just starts suddenly printing it offset from the previous layer.Quote
Gaou
when this happens to me it is always a nozzle hitting on the print makes it lose steps...! do you watch the print from the beggining to the end ?
I've already tried reducing the speed and acceleration. Speed is currently ~30mm/s for printing, and 60mm/s for traveling. The acceleration is 20mm/s2. I've printed a much larger and longer object before, around 16cm x 5cm x 20 cm tall, and I didn't get this issue. Now, even if I print a 40mm calibration cube it gets this misalignment between layers.Quote
o_lampe
The most significant difference between two or three clamps is the longer travel distance with three clamps.
You could try to reduce travel speed and accelerations in general.
Re: Issues with printing larger objects March 26, 2017 03:10AM |
Re: Issues with printing larger objects March 26, 2017 01:14PM |
I'm not sure if that's the case, but I don't think I can rule it out entirely either. I've had prints fail early as the second layer, to as late as 20 min in during a 40mm hollow cube. Printing two clamps is always successful, and takes 40 min, so I'm not sure it's related to time or just chance. I'll double check the solder joints regardless though, just to be safe.Quote
o_lampe
The misalignment seems to be in perfect 45° direction?!
If a H-Bot has same kinematics as a CoreXY, this indicates one of the steppers competely fails. I'd check the hardware and wiring for cold solder joints or broken wires.
Re: Issues with printing larger objects March 30, 2017 06:43AM |
o_lampe
Ok, I opened up the XY steppers and there doesn't seem to be anything visually wrong in there. I also realigned the entire Z axis (I had some new mounts and proper leadscrews to install). I have a little issue with juddering on the Z axis, but nothing concerning.Quote
A_Designs
Re: Issues with printing larger objects March 30, 2017 07:30AM |
Re: Issues with printing larger objects March 30, 2017 09:24AM |
At this point, I'm desperate enough to try anything, this issue has been on my head for a month now. Earlier, it didn't make any sounds or movements to indicate nozzle catches, so I dismissed it fairly early on. Just now, I enabled Z Hop in cura, and it hops perfectly with my new leadscrews. On another note, I'm using a SD card loaded with .gcode, and a discount LCD controller.Quote
obewan
Have you tried a print with 'avoid crossing perimeters' set or maybe with 'Z hop' set. This would remove the possibility of the nozzle snagging on the centre piece.
Sorry if this is a stupid idea
Re: Issues with printing larger objects March 30, 2017 09:34AM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: Issues with printing larger objects March 30, 2017 09:45AM |
The current's at its max, and I've used new stepper motor drivers just in case, but still the same issue. I'm microstepping at 1/16 with A4988 drivers. It also doesn't make any sounds like missed steps or impacts when the deviation shows up.Quote
VDX
... still looks like loosing steps - have you tried to rise the motor current?
Re: Issues with printing larger objects March 30, 2017 10:46AM |
Re: Issues with printing larger objects March 30, 2017 10:52AM |
My stepper's have standard D shafts, and the pulleys are locked on tight. They're definitely not the problem, and I've put marks on the pulley to check if there was any slipping, and it's rock solid. I thought it might be the endstops falsely triggering, but I get no messages about that, and I tried triggering the endstops with my fingers during a print, and my printer kept going as if it didn't care, so it's not that either.Quote
VDX
... there were similar effects with slipping gears, not enough fixed on the motor shafts ...
Re: Issues with printing larger objects March 30, 2017 11:50AM |
Re: Issues with printing larger objects March 30, 2017 12:07PM |
Missing steps creates a audible sound, so I would have noticed it. I tried tuning my drivers with vref, but that turned out to be way too low, so I tuned it until I didn't get any more torque when increasing, and only more noise.Quote
Floyd
Im still going with current needs to be higher. I have to have mine REAL high and the motors burning hot otherwise ill miss steps.
Re: Issues with printing larger objects March 31, 2017 11:20PM |
Re: Issues with printing larger objects April 01, 2017 12:42PM |
Re: Issues with printing larger objects April 05, 2017 11:31PM |
Re: Issues with printing larger objects April 06, 2017 06:49AM |
Ok, how should I check if that's the case? I've tried printing at really slow speeds, and I've set my SD card speed to halfrate just in case.Quote
kentmcn
It looks like both X and Y axes are affected and at the same time--as if the Arduino was overloaded, the RAMPS board couldn't produce enough power, or the SD communication was losing packets.
Why the system would add (or subtract) to both X and Y though, seems odd.
Maybe try to reduce the processing load on the Arduino? Check the power that's available throughout the print? And check the buffer sizes?
Re: Issues with printing larger objects April 06, 2017 08:26AM |
Re: Issues with printing larger objects April 06, 2017 09:21AM |
Re: Issues with printing larger objects April 06, 2017 11:48AM |
HBots and coreXY's are a pain to troubleshoot, because if only one motor is turned, then the head moves diagonally, and if the other is turned, then it goes diagonally perpendicular to the first one. If one is turning, and the other skips, jumps, or stutters, then it'll cause the head to get misaligned, and depending on which direction the head was Supposed to be moving in, it gets misaligned one way or the other. I tried recording it, but it's such a small deviation, and it happens so quickly, that you can't really notice it's in the wrong spot until it's printing in the air.Quote
sigxcpu
kentmcn
Because it is a H-bot and one motor moves at 45/135 degrees?
the_digital_dentist
You said the motor is getting hot. That means the current is high, which means the driver module is probably overheating and shutting itself down to protect itself. After a brief interval it cools enough to turn on again and then promptly overheats again, missing steps along the way. That would explain why it's OK for a little while and then starts failing. Those little driver modules are just a crappy design. They do not have sufficient surface area to cool the chips, and taping a tiny little heatsink onto the chip doesn't work. Turn down the current.
I am running a pretty massive coreXY mechanism with two little 64 oz-in motors at 1000mm/s^2 acceleration and up to 150 mm/sec print speed and they literally don't get more than 5C above ambient temperature. If you need a lot of current to move the mechanism the mechanical alignment of the rails and bearings is probably off. It may have been fine before you put the belts on but the belt tension puts a lot of force on the mechanical stuff and may have pushed it out of alignment enough to cause binding or at least a lot of resistance to motion.
[vimeo.com]
Re: Issues with printing larger objects April 06, 2017 12:17PM |
Re: Issues with printing larger objects April 09, 2017 11:39AM |
Re: Issues with printing larger objects April 10, 2017 01:39PM |
Re: Issues with printing larger objects April 24, 2017 07:12AM |
Re: Issues with printing larger objects April 24, 2017 11:37PM |
Re: Issues with printing larger objects April 25, 2017 07:18AM |
Re: Issues with printing larger objects April 25, 2017 07:27AM |
MCcarman
Since the layers print OK, what happens if you reduce the move speed to the same as the print speed? That should rule out speed related issues.
I don't know much about H-Bots but I assume motor synchronisation is critical.
Assuming the firmware is configured correctly then differences in the drivers may have an effect. Just speculating but wire size and length differences?
