First Layer Settings June 25, 2017 03:54AM |
Re: First Layer Settings June 25, 2017 09:33AM |
This you got wrong, AFAIK. Z offset affects the height of the nozzle ONLY. Modifying the first layer height affects the height AND the amount of filament extruded.Quote
hobbymods
I haven't tried any Z offset yet, as it seems that it would have the same affect as lowering the first layer height.
Re: First Layer Settings June 25, 2017 12:04PM |
Re: First Layer Settings June 25, 2017 03:42PM |
obewan
When i print at a layer height of 0.2, i set the initial layer height at 0.35 with 120-150% extrusion. this should fill in your gaps in the bottom layer.
When you set your 1st layer height down to 90% i think you are moving the nozzle too close to the bed and restriction the extrusion,
Re: First Layer Settings June 26, 2017 06:39AM |
Re: First Layer Settings June 26, 2017 08:55AM |
Very different things. What did you set the bed gap to? If you set it with a feeler gauge you must have a gap and that should be your Z offset.Quote
Re: First Layer Settings June 27, 2017 09:57PM |
