Top layer quality issue
August 16, 2017 05:14AM
Hi
I am having trouble with top layer, it has some lines higher than others, plus looks like scar lines and I get missed lines, please look at image I have attached, I am using cura for slicing. Any ideas?
open | download - 20170815_223311-1032x581.jpg (175.5 KB)
Re: Top layer quality issue
August 21, 2017 11:19AM
Possibly over extrusion causing the nozzle to flatten the bead. Where it stops and starts the filament can go sideways and it forms a ridge. The diagonal drag mark shows you don't have a lift on move value set.
I am not familiar with cura so can't tell you the exact settings.
August 21, 2017 03:06PM
Hi
Thank you for your advice, it's been driving me crazy as it's a good printer but really struggling on top surface. I understand the over extrusion, but I am not sure about the lift on move, I will have to Google that lol.
August 23, 2017 03:00PM
It's called Z Hop on retraction. I have mine set at .5, which is slightly more than the thickest layer(usually .2) I intend to print.
August 23, 2017 04:33PM
Hi JmRobert
I will try that now, surface quality is a lot better now I have used mccarmens advice but still can't get rid of the travelling line.
August 24, 2017 10:12AM
Hi both of you
I have tried less flow multiplier and the surface is a lot better, but zhop did not stop printer leaving this line on print, I assume it's a travel line, any other ideas, print looks fine but line ruins it.
Thank you
open | download - 20170823_231629-1024x576.jpg (125.3 KB)
August 25, 2017 02:33AM
Have you tried combing mode "no skin" or "off" in combination with z-hop?
August 25, 2017 02:45AM
Hi lars
No haven't tried that yet, did notice the combing check box is ticked, I will try turning it of. I don't know where to find the no skin feature ?
August 25, 2017 06:01AM
I use Cura 2.6 and 2.7-beta atm. Don't know what version it was added, sorry...
August 25, 2017 07:16AM
Z-Hop should have worked. What settings did you use? I don't know Cura but it may not be enough to just turn it on. You have to set a height. JM said its "Z hop on retraction" so you may need to have retraction turned on as well.
August 25, 2017 07:56AM
Retraction is turned on and I set the z hop to .5 also I will try cura 2.6 and see how that goes.
