Cura setting for layer height. June 04, 2019 04:17PM |
Re: Cura setting for layer height. June 04, 2019 04:59PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Cura setting for layer height. June 05, 2019 06:13AM |
Re: Cura setting for layer height. June 05, 2019 08:55PM |
Re: Cura setting for layer height. June 06, 2019 02:54AM |
Re: Cura setting for layer height. June 06, 2019 06:15PM |
Re: Cura setting for layer height. June 07, 2019 03:47AM |
dlw
I simply do not understand how to make changes in the Settings menu.
The only change that can be made is in Materials.
How is the infill density changed?
Top and bottom thickness.
See attached.
Re: Cura setting for layer height. June 07, 2019 09:34AM |
Re: Cura setting for layer height. June 07, 2019 10:30AM |
dlw
Thanks Ohmarinus.
The print is about to start.
I will let you know how it goes.
Thanks again,
dlw
Re: Cura setting for layer height. June 13, 2019 10:03AM |
Re: Cura setting for layer height. June 13, 2019 12:24PM |
Re: Cura setting for layer height. June 13, 2019 12:43PM |
Re: Cura setting for layer height. June 14, 2019 08:13AM |
Re: Cura setting for layer height. June 14, 2019 04:52PM |
Re: Cura setting for layer height. June 14, 2019 11:36PM |
Re: Cura setting for layer height. June 15, 2019 12:46PM |
Re: Cura setting for layer height. June 16, 2019 12:38PM |
Re: Cura setting for layer height. June 16, 2019 04:00PM |
Re: Cura setting for layer height. June 16, 2019 07:40PM |
dlw
The attached was printed with 230, 60, .05 nozzle, speed 50mm, layer height .16.
How is the feed rate changed in Cura 4?
Re: Cura setting for layer height. June 17, 2019 10:05AM |
Re: Cura setting for layer height. June 17, 2019 10:26AM |
dlw
Yes, the nozzle is set to .05.
As stated above: The attached was printed with 230, 60, .05 nozzle, speed 50mm, layer height .16.
Re: Cura setting for layer height. June 17, 2019 12:33PM |
Admin Registered: 16 years ago Posts: 13,902 |
Re: Cura setting for layer height. June 17, 2019 05:06PM |
dlw
Re: Cura setting for layer height. June 17, 2019 06:53PM |
Re: Cura setting for layer height. June 18, 2019 09:41PM |
Re: Cura setting for layer height. June 29, 2019 04:18PM |
Re: Cura setting for layer height. June 29, 2019 07:36PM |
dlw
OK, back on line. Same problem.
How to change feed rate in Cura 4?
Also, what in the attached setting is causing a 5 hour print?
Re: Cura setting for layer height. June 30, 2019 04:27AM |
Re: Cura setting for layer height. June 30, 2019 02:52PM |
Re: Cura setting for layer height. June 30, 2019 04:24PM |
dlw
Changed to .4 nozzle because many of the attached are needed.
Tried layer heights from .16 to .6. No luck.
The printer tries to print layer 1 again and again.
Z axis does not move.
