Ender 5 keeps pausing while printing June 23, 2019 07:29AM |
Re: Ender 5 keeps pausing while printing June 23, 2019 08:47AM |
Re: Ender 5 keeps pausing while printing June 24, 2019 12:37PM |
ken88
Worked it out now.
It was the Utimaker Cura 4.0.0 slicer software
I done the same part with Crealty 1.2.1 slicer and it ran start to finish.
So I will try and reinstall Cura and try it again.
Re: Ender 5 keeps pausing while printing July 06, 2019 08:03PM |
Re: Ender 5 keeps pausing while printing July 08, 2019 02:47PM |
PDBeal
From what I’ve read, the problems with Cura 4.0+ are related to your machine definitions not specifying max feed rates. The latest Cura just assumes the speed of light for some stupid reason and 8-bit boards seem to get confused with it. This is what I understand causes the machines to pause for a short time to figure out what to do before continuing. You can see this if you download the machine settings plugin from the Marketplace inside of Cura. If you specify the feed rates in machine settings or in your machine definition it’s not an issue as it uses the specified feed rates.
