E1 Heating failed, printer Halted, please reset? Help January 22, 2020 04:31PM |
Re: E1 Heating failed, printer Halted, please reset? Help January 22, 2020 06:48PM |
Admin Registered: 13 years ago Posts: 7,010 |
Re: E1 Heating failed, printer Halted, please reset? Help January 23, 2020 04:08AM |
Re: E1 Heating failed, printer Halted, please reset? Help January 23, 2020 05:27AM |
Re: E1 Heating failed, printer Halted, please reset? Help January 23, 2020 07:11AM |
Re: E1 Heating failed, printer Halted, please reset? Help January 23, 2020 07:15AM |
Dust
The error is basically saying "I'm applying power and its not getting hot enough quick enough."
Common causes,
Thermistor not making good contact with heater block.
Heating element not firmly attached to control board (loose screws)
and less rare (But I suspect this is your issue)
using wrong heater cartridge (eg a 24v cartridge on a 12v system) (e3d have both...24v and 12v)
Do you still have the old heater cartridge ? Got a multi meter? measure the resistance.
Unplug your new heater cartridge from the controller and measure the resistance of this also.. are they the same?
Re: E1 Heating failed, printer Halted, please reset? Help January 23, 2020 08:30AM |
Re: E1 Heating failed, printer Halted, please reset? Help(solved) January 27, 2020 04:47AM |
Re: E1 Heating failed, printer Halted, please reset? Help May 04, 2021 08:50PM |
Re: E1 Heating failed, printer Halted, please reset? Help June 27, 2021 01:05PM |
Re: E1 Heating failed, printer Halted, please reset? Help June 28, 2021 01:47PM |
RonArt
SOLVED! Now my nozzle is tightened flush with the heating block
