fma
'skirt' feature
December 08, 2011 07:22AM
Slic3r first moves down the hot-end to the first layer Z value, then moves to the XY location. I think it would be better to first move to XY location, *then* to go down to the first laye Z valuer. This will avoid the little blob in the middle of the print area...
Frédéric
Re: 'skirt' feature
December 08, 2011 11:15AM
Don't you home before printing? Is your home point in the middle of the print bed?
I always home (G28) before printing, so the Z move happens with the extruder at position 0,0.
fma
Re: 'skirt' feature
December 08, 2011 01:07PM
Yes, my homing position is in the center of the print bed. This is easier to check if the object fits (I only have a small hot-bed, for now).
Frédéric
Re: 'skirt' feature
December 08, 2011 06:28PM
I also have my home in the center.
Also G28 is not a homing code but the early RepRap firmware improperly implemented it as homing and sprinter, marlin etc have continued doing it wrong. Teacup is the only firmware for RepRap that I know of that implemented the code correctley.
G28 is supposed to return to the reference point not find home. Find home is supposed to be G161 and G162.
fma
Re: 'skirt' feature
December 09, 2011 01:46AM
I think G28 is OK. The problem is about vocabulary: home # reference...
Frédéric
Re: 'skirt' feature
December 09, 2011 04:32AM
If you home to the center point and your extruder oozes too much, you can add a custom command to your start gcode procedure to move to another point so that the Z change doesn't happen in the center. For example:
G1 X0 Y0
This will move to 0,0. Z change will happen there.
fma
Re: 'skirt' feature
December 09, 2011 07:09AM
Ah, yes, good idea!
Thanks.
Frédéric
Re: 'skirt' feature
December 10, 2011 04:33PM
G28 now causes teacup to home, so as to be compatible with other firmwares and hostwares
Wooden Mendel
Teacup Firmware
