printing a perimeter layer around voids June 09, 2012 04:39PM |
acceleration = 0 bed_size = 200,200 bed_temperature = 0 bottom_layer_speed_ratio = 0.3 bridge_fan_speed = 100 bridge_flow_ratio = 1 bridge_speed = 60 cooling = 0 disable_fan_first_layers = 1 duplicate = 1 duplicate_distance = 6 duplicate_grid = 1,1 end_gcode = G1 X12.0 F4000 ; home (almost) x - stops extruder crashing into frame if at very top of Z height\nG1 Y170 F4000 ; move the print to the front.\nM104 S0 ; make sure the extuder is turned off.\nM140 S0 ; make sure the bed is turned off.\nM84 ; shut down motors. extrusion_axis = E extrusion_multiplier = 1 extrusion_width_ratio = 0 fan_always_on = 0 fan_below_layer_time = 60 filament_diameter = 1.75 fill_angle = 45 fill_density = 0.3 fill_pattern = honeycomb first_layer_bed_temperature = 0 first_layer_height_ratio = 1 first_layer_temperature = 184 g0 = 0 gcode_arcs = 0 gcode_comments = 0 gcode_flavor = reprap infill_acceleration = 50 infill_every_layers = 1 infill_speed = 45 layer_gcode = layer_height = 0.12 max_fan_speed = 100 min_fan_speed = 35 min_print_speed = 10 notes = nozzle_diameter = 0.35 output_filename_format = [input_filename_base].gcode perimeter_acceleration = 25 perimeter_speed = 20 perimeters = 1 post_process = print_center = 0,0 retract_before_travel = 0 retract_length = 0 retract_lift = 0 retract_restart_extra = 0 retract_speed = 40 rotate = 0 scale = 1 skirt_distance = 0.1 skirt_height = 1 skirts = 1 slowdown_below_layer_time = 15 small_perimeter_speed = 35 solid_fill_pattern = rectilinear solid_infill_speed = 60 solid_layers = 1 start_gcode = G28 ; home all axes\nG92 E0 ;reset extruder\nG1 E3 F1200 ;Prime extruder 3mm\nG1 E2 F1200 ;retract extruder 1mm\nG92 E0 ;reset extruder support_material = 0 support_material_tool = 0 temperature = 184 travel_speed = 60 use_relative_e_distances = 0 z_offset = -100
Re: printing a perimeter layer around voids June 10, 2012 01:01AM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
