Slic3r 1.2.4 Settings & Terrible Prints January 23, 2015 11:02AM |
Re: Slic3r 1.2.4 Settings & Terrible Prints January 23, 2015 12:33PM |
Re: Slic3r 1.2.4 Settings & Terrible Prints January 23, 2015 02:35PM |
Re: Slic3r 1.2.4 Settings & Terrible Prints January 23, 2015 02:55PM |
Re: Slic3r 1.2.4 Settings & Terrible Prints January 23, 2015 03:54PM |
Here it is with the extrusion multiplier 0.57, print speeds 70mm/s, first layer width 100%, first layer speed 40%:Quote
dmould
I suggest try changing to an extrusion multiplier of around 0.83, print speeds of 70mm/s or less, first layer extrusion width of 100% and first layer speed reduction of 40% and see what result you get. If that's OK, you can try increasing your speeds.
Dave
Re: Slic3r 1.2.4 Settings & Terrible Prints January 23, 2015 04:20PM |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Slic3r 1.2.4 Settings & Terrible Prints January 26, 2015 08:43AM |
Re: Slic3r 1.2.4 Settings & Terrible Prints January 26, 2015 11:20AM |
This morning when I turned on the machine, both heads reported 24C, which indicates their temperature is accurate at the low end. For these prints, I changed the head temperatures from 220C to 240C and nothing else. The box is now square, so that is an improvement. But it still is not good like what I was getting from Skeinforge on the same printer with the same roll of filament:Quote
Wurstnase
Your problem is not slic3r. Reduce the speed or increase your temp.
Only increasing the temp you should need 10 to 20°.
Re: Slic3r 1.2.4 Settings & Terrible Prints January 26, 2015 02:23PM |
Re: Slic3r 1.2.4 Settings & Terrible Prints January 26, 2015 03:24PM |
Re: Slic3r 1.2.4 Settings & Terrible Prints January 27, 2015 07:56AM |
Re: Slic3r 1.2.4 Settings & Terrible Prints January 27, 2015 11:55AM |
Re: Slic3r 1.2.4 Settings & Terrible Prints January 28, 2015 10:14AM |
Re: Slic3r 1.2.4 Settings & Terrible Prints January 29, 2015 10:37AM |
Re: Slic3r 1.2.4 Settings & Terrible Prints January 29, 2015 11:48AM |
kda406
I'm using 1.2.4. Can anyone verify that the extrusion multiplier works on Win7 Pro 64 bit? Looking at the picture history, once I slowed the print down, it looks like I get the same results regardless of which extrusion multiplier number (0.57, 0.83, 1.00) I use on the 20x20x10 cube.
Thanks so much,
Kyle
Re: Slic3r 1.2.4 Settings & Terrible Prints January 29, 2015 12:53PM |
Re: Slic3r 1.2.4 Settings & Terrible Prints January 29, 2015 03:05PM |
Kurzaa
Still new to 3D printing, but I was thinking the extrusion multiplier was for minor adjustments and that anything beyond 0.05 (0.95-1.05) was an indication of a poorly calibrate extruder motor.
Re: Slic3r 1.2.4 Settings & Terrible Prints January 29, 2015 03:53PM |
Interesting thought. My custom G-code does not call out either. "Use relative E distances" is not checked on my Slic3r settings.Quote
dmould
The "Custom G-code" in Slic3r should set the printer to either relative (M83) or absolute (M82) mode, and there is a tick box under "General" printer settings to set relative E distances (checked) or absolute (unchecked). Either have M83 in the custom code and the box checked, or M82 and the box unchecked.
Re: Slic3r 1.2.4 Settings & Terrible Prints January 30, 2015 09:59AM |
kda406
dmould
Unfortunately, neither the Slic3r nor Skeinforge gcode files call out M82 or M83 anywhere in them. I have attached both the Skeinforge gcode which is smooth and puts out too much plastic, as well as the Slic3r gcode file. I zipped them so they would fit on the forum.
Thanks,
Kyle
Re: Slic3r 1.2.4 Settings & Terrible Prints April 28, 2015 06:43PM |
Re: Slic3r 1.2.4 Settings & Terrible Prints [SOLVED] June 12, 2015 09:50AM |
Re: Slic3r 1.2.4 Settings & Terrible Prints [SOLVED] June 14, 2015 11:00PM |
Re: Slic3r 1.2.4 Settings & Terrible Prints August 16, 2015 02:12PM |
