Slic3r problem in W7x64
October 27, 2012 10:34PM
Hello! I have a big problem with running slic3r on Windows 7 x64. Slic3r 0.9.3 it is not started at all - the program window doesn't appear, only process in memory on 3-4 seconds. When i start slic3r 0.8.4, main window appear, but when I drag&drop any stl file (for example [www.thingiverse.com] or [www.thingiverse.com]), slic3r closed. Windows parametres : Windows 7 x64 SP1. I try to run in work computer, no 3D printer attached, want to make G-code. Run .exe file, no git. Try to run console version, it runs and works. Graphical version I try to run on 3 computers (all W7, x64 and x32), the same bad result at all.
Edited 2 time(s). Last edit at 10/27/2012 10:38PM by andy_111.
Re: Slic3r problem in W7x64
October 28, 2012 07:51AM
Do you use a non-English Windows?
October 28, 2012 10:12AM
Yes, my Windows is Russian. You think, that problem in slic3r in non-Russian Windows? That's strange...I am programmer and don't understand, how it can be.
November 01, 2012 12:14PM
There is problem in Wx:confused smileytandardPaths::Get->GetUserDataDir - unicode path is interpreted as local codepage string.
[github.com]
using --datadir or creating directories with (expected) invalid name will help.
August 01, 2013 11:06AM
well the same thing happens to me, I use window in Italian .... could you give me a solution? thanks
August 01, 2013 06:24PM
I had a similar problem with all my laptops with the Norwegian version of Windows( XP, Vista and Win 8).
My laptops with the English version of Windows works great.
My name is Torbjørn, and as Ø is a nordic letter which creates problems in Slic3r.
The laptops with the english version of Windows transfers the Ø into ASCII characters.
At least this is what I think is Nicolòs problem if this is the login name on Windows. As I do not know Andy_111s real name, I can just asume smiling smiley
Try to generate a new windows user with only ASCII characters, and I think you should be OK.
August 02, 2013 01:52AM
Had similar problems with login name with danish chars.
Make a new Windows user login with ascii chars only in name.
