Feature Request: Fan Pulse Mode
Posted by pyrophreek
May 01, 2013 04:24AM
Rather than adjust the fan PWM, as some fans don't support this well, use a pulse mode either short pulses at the beginning of a layer, or at regular intervals. Every n layers might work too. I have tried this manually on my Solidoodle 2 and found it to work very well at improving print quality, but is tedious.
Edited 1 time(s). Last edit at 05/01/2013 04:43AM by pyrophreek.
Re: Feature Request: Fan Pulse Mode
May 01, 2013 07:26AM
You might change the PWM pulse duration in your firmware, this would have the same effect
May 01, 2013 12:21PM
Tried looking into this, but couldn't find info on how to do it. Any links to what setting to change?
May 01, 2013 01:04PM
Depents on your Firmware, e. g. for Repetier [github.com] whis is where the S-value from pwm_pos[3] (if you use 1 extruder) to create the pwm signal,
maybe asking someone from the firmware section
